1984 4 wheel drive Model 5015 |
nhmath
Bronze Level Joined: 28 Sep 2023 Location: Delaware Points: 5 |
Posted: 28 Sep 2023 at 4:56pm |
Hi, When I put the 4 wheel drive lever down It does not engage the fron wheels. Please HELP. Neil
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4728 |
Thanks(1)
Haven’t worked on the 4x4 5015, did you follow the lever to see where it goes to make sure you don’t see something that has come loose?
nhmath
Yes. it seems to try and lock in but at the point of lock in it looks jammed.
AC720Man
Can you post a picture of the linkage?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78480 |
jammed like the gears are not meshing ? ....Sometimes rolling slowly or bumping the clutch to rock the tractor will allow a gearbox to mesh. ( like a transmission).
nhmath
Thanks I will give it a try.
nhmath
Will do as soon as I can.
Jasonw
Bronze Level Joined: 11 Dec 2017 Location: MD Points: 60 |
The front drive shaft is driven via a sprocket and roller chain on the rear pinion shaft. The chain or keyway for the sprocket could be broken.
