What did you do with your Allis Today? |
Post Reply | Page 123 21> |
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8863 |
Posted: 10 minutes ago at 12:58pm |
Left the key on my 180 diesel in the on position. Ran the battery down. Put it on the charger this morning.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3167 |
Hopefully the rain pushed the seed in some for you.
I worked the seed bed for second sweet corn with 190XT and 3pt harrow. Planted it with 170 pulling JD494. Then the 7040 and 1350 FC to get beans done with the 7045 and DA385. I tried (miserable fail) to se the WD45 and SC 3 bottom to turn some sod for the garden expansion. It’s been a long time since I’ve run an outfit like that. Dad had his WD with six cylinder conversion pulling a similar plow but he had it set up and all I did was operate it for a while. This time around I need to learn to set the thing up to work together and a small plot is no way to learn. |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3482 |
Had a mostly Orange weekend. Saturday, dumped some gas in WD Micha and headed back over to the neighbors to reseed his waterways I did back in April. They were looking good, until, the coop sprayed the corn in 25 mph wind. Wow, they smoked them s.o.b's. They used to spray for me but no longer, new guy seems to be doing a good job. After returning home I did some work on the North drive with the 856 and big-ox blade. That was the non-Orange part. It also went for a tractor ride later on. Once I got that hard packed clay scraped off, got CA-2 out and drug the harrow section around. That thing really worked great for that, probably used less fuel than the 45 would have too. Sunday, seeded some grass on the North side of that drive where Dan got the clay for the building pad. Drill is staying on that WD until the building is done and I can reseed the rest of the yard. More harrowing with CA-2. Then loader work with the 6080. Had some stumps ground back in February, dug the chips and dirt out and moved to the burn pile. Well, got one done and two partial scoops out of the other. Filled the hole with black dirt Dan saved me from the pad. Got some seed on it between showers but it just cut loose before I could rake it in. Guess we'll see how that goes!
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2218 |
sold one, junked one and deep sixed one! Got more to go!!
plummerscarin
My accountant and I have been clearing an area for a larger garden and we've been dismantling an old mobile home on the property. The 170 moved some small items such as an All Crop drill and a sprayer. After that we hooked up a new to us 190XT to brush mow the area
The 200 was called in to pull some small trees and relocate the MH frame to another spot for cutting up. 190XT back in action with the spring tooth harrow to work over the sweet corn patch. The 170 will pull the JD 494 we got from 200Tom tomorrow hopefully |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1022 |
Took the wd45 out with the 2 bottom disk plow i got from farmer zzz . Plow seemed to work pretty well, need to adjust one of the scrapers. Tractor struggled with traction which surprised me. Both rear tires are brand new and loaded with beet juice. Guess i am going to add some weight to the land wheel
IBWD MIke
Saturday, 5-4, changed starters in the NF 45. Old one shot craps the Sunday before. Changed it then to one that was 'on the shelf'. Had another one that was on the shelf too that was dead. Out of curiosity I called Ankeny auto electric to see how much longer they were going to be open. Today and one more was the answer, rats! He asked what I needed? Explained the situation, bring them up, we'll get them done. That changed the course of my day but I happily hauled two starters and an alternator there. Alternator checked good and we talked about the 6-12 volt thing. They set both up for 12 volts. Thought I might as well put a correct one in the tractor, they were taking up space on the bench I needed to do some brake work on a Farmall, easy way to make space! The other will go in the WF 45 as soon as it gets close to the shop. I just started using this shop a couple months ago, really sucks they are retiring. They sold to some younger guys that are moving it to Slater. That will add about 40 miles to the journey. Probably give them a try sometime in the future. The old hindsight thing. Had I found out about these guys a year earlier, they would have gone through every starter and alternator I own!
plummerscarin
There are 2 here. One has some pieces missing. This is complete but I wonder if anyone is interested in them.
IBWD MIke
I've moved four row heads like that but never a six. Hauled one of those heads about 7 miles to the junkyard.
plummerscarin
Gave the 3pts a workout today on the 170 and 7040 moving things around. We want to expand the garden a bit and these were in the way
Had to brake steer the big one |
IBWD MIke
Thanks(1)
Saturday, 4-27 I took the NF 45 on a tractor ride out of Liberty Center Ia. First time that girl has gotten picked. It was the easiest one on short notice. Preformed admirably! Have I ever mentioned to you guys how much I love that tractor? There were only 10 riders. One other Allis, a nicely restored D-19 gas. Two Fords, four Farmalls, a Minnie, and one lone deere. Beautiful country down in Lucas Co. WE drove several miles of 'Minimum maintenance', aka, dirt roads that were marginally dry. At any rate it was a fun day!
IBWD MIke
Your furrow is really straight! Must be doing something right. A lot of plows sitting out here, I run a wire brush on a 4" grinder over them then a flap wheel. That speeds the scouring. Anything that gets that much elbow grease I try really hard to keep inside after that! Made it over to the neighbors with the WD and Drill. He had a bit more to do than I expected! Went through 4 bags of oats and 2 bags of grass. His son was flagging where I seeded and having a hard time keeping up!
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
a good coat or two of black enamel weathers much better than grease
plummerscarin
7040 and 4 bottom plow. Turned over an acre of sod.
Go easy on me. This plow has not been used in 10 years and sits outside. The grease washed away so the sod didn't slide as well as it should and didn't shine up much but its done. With no guidance I adjusted as seemed appropriate. |
E7018
Bronze Level Joined: 07 Dec 2009 Points: 167 |
I used loader on D17 to push Polaris ranger in shed for bad fuel pump. AGAIN.
MadCow
Bronze Level Joined: 27 Aug 2023 Location: South Dakota Points: 103 |
Graded my driveway with the blade. Fixed the entrances where the county dug nice ruts when they did the road, and added a better drainage pitch and smoothed the rest of the run. It was a blast.
IBWD MIke
Going to throw the All-Crop Drill on WD Micha today. Buddy of mine has some waterways that need seeded, going to do that Saturday or Sunday. I love running that little drill! Not sure if I have any that need done this year or not? Need to get out and have a look.
ksbowman
Silver Level Joined: 19 Mar 2013 Location: Paola, Ks Points: 226 |
Took the bale spear off the 180 and put the bucket on. Brought up 14 buckets full of compost and put on the garden. Hadn't done this for two years and it needed it.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8160 |
I didn’t do anything with tractors but Iv been taking inventory, handling allis chalmers NOS parts most of the winter. If that counts
plummerscarin
I hope to make the NF 45 here more useful as well now that I have it running again. One item is returning the snap coupler hitch to the New Idea rake and use it as I did growing up
IBWD MIke
There would be a lot less joy here at the farm without that NF 45! So handy. About 90% of the time when things need to get shuffled around, it gets the call.
AC WD45
Orange Level Joined: 28 Sep 2009 Location: Mid Michigan Points: 1993 |
Got the #17 loader mounted today, moved some dirt around the yard. Works awsome. Talk about a trip down memory lane. We had a #17 loader just like this on this tractor when I was growing up. |
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
plummerscarin
Pulled the 3pt blade over the driveway with the 170. No fun being out in the wind today
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2585 |
Yesterday I put the new 20" disc on and used My D 15 to disc up our roads/firebreaks. Thanks
HaroldOmaha
Orange Level Access Joined: 11 Sep 2009 Location: Omaha Points: 862 |
Took my WD45D and WD45 propane to the Nebr. Tractor Test station 100th Anniversary
a few months back. another gent had a 220 that was the tractor that was tested there. i know a few people that have Allis's that were tested there.
IBWD MIke
No idea what brand that spring-tooth is but see your accountant making a cameo in the picture. I disced the garden with the NF 45 and did a bunch of loader work with the 6080. The dirt in the garden is REALLY mellow! Was going over the spools on the disc. Even planted some radishes and turnips.
plummerscarin
Have a few areas in the pasture that need reseeding due to stump pulling and heavy cattle traffic. Used the 7045 to work these areas with a smaller disc then a 3pt spring tooth harrow
As an aside, does anyone know what brand/model this is? Its orange but no markings I can find |
ACinSC
Favorite son posted a couple pictures for me .
Today I removed the broken center piece. I'll shop for a new disc soon , Thanks. |
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9694 |
Repair starter on my CA had to replace the solenoid
WeisAC2
Bronze Level Joined: 02 Feb 2017 Location: Aiken SC Points: 110 |
