Allis 175 hydraulic pump input shaft |
steve(oh)
Bronze Level Joined: 12 Sep 2009 Location: ohio Points: 107 |
Posted: 30 Jul 2023 at 1:42pm |
Happy sunday. Can I take this shaft out with out running into problems of stuff dropping behind it. Or how do I go about it? Split the tractor for the clutch and the bushing was hanging out on the smaller input shaft. IMG_6041.jpeg
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake |
8070nc
Silver Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 416 |
I dont know what Doc or Mack would say but I think Id get a new bushing and put some locktite on it and tap it back in there.
1984 80780
Orange Level Access Joined: 12 Sep 2009 Points: 19668 |
Over the years, I've actually removed a couple of those bushings because the tractors clutch shaft was dragging and making it difficult to shift into gear without constant grinding of the gears. Removal of that bushing cured the problem.
MACK
Can't see much the bushing does with a good piolet bearing and pressure plate is rigged. MACK
steve(oh)
Thank you. In that case I will just leave it out and put the new clutch in.
I’m sure others have thought about this and may have mentioned it. But if you ever wanted to record hours of Allis knowledge, Dr I would pay for it to happen! |
