New Member |
UPBUSHMIKE
Topic: New MemberPosted: 26 Jul 2023 at 10:46am |
Hi. This is Mike from Upper Michigan. I am rapidly converting to be an avid Allis fan after recently aquiring (2) Allis CA’s. My foray into the Allis world happened after buying an Allis loader and a parts CA that it was mounted on. So basically, I buy a $100 loader and find a tractor to fit! I found and purchased another running CA (sn#2400) that had B front end on it. The parts tractor (sn#18725) had the correct wide front and associated steering gear. It was an easy swap. I purchased reprints of both the service manual and the operating instructions/repair parts manuals for the CA. I was quite surprised at the power this little tractor had when pulling a 2/14 plow and a 6’ tandem disc! Sure wish I could post pics!
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3254 |
Posted: 26 Jul 2023 at 11:04am |
Welcome Mike , lots of knowledgeable guys on here if/when you have questions .
Joined: 11 Sep 2009 Location: illinois Points: 90980 |
Posted: 26 Jul 2023 at 1:00pm |
Mike, i dont know at what point you get that you cant post photos... Under the LAST POST on this page you can do a "QUICK POST" ... or you can click on the "POST REPLY BOX" above that.... You will then get a page that allows you to post photos.. Click on the GREEN TREE and go from there..... more questions if you have problems.
Photos about 800 x 600 pixels work best and 100 kb of data... If your on a cell phone, the photos can be 5000 x 3000 and 5 MB large.. that dont work.. e-mail to yourself and RESIZE... or go on computer and do it in PAINT..
UPBUSHMIKE
Posted: 26 Jul 2023 at 1:27pm |
Thanx for the pic help! Can anyone ID this loader? I am assuming its Allis. Base paint is Allis orange.
UPBUSHMIKE
Posted: 26 Jul 2023 at 1:33pm |
Another pic
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11426 |
Posted: 26 Jul 2023 at 1:36pm |
Don't know what the loader is but that's a nice looking Allis Chalmers CA
UPBUSHMIKE
Posted: 26 Jul 2023 at 1:42pm |
Thanx! Here are the two
I started with.
UPBUSHMIKE
Posted: 26 Jul 2023 at 1:44pm |
And another of the B wide front on the CA.
Steve in NJ
Posted: 26 Jul 2023 at 2:31pm |
Mike, Welcome to the land of AC! More knowledge on this forum than at the Library. Some fellers on here bleed Orange not Red. The only dumb question is one that isn't asked. Some of the fellers on here sell new & used parts (like myself) so you can acquire needed parts as well. Super people on here ready to help ya out in any way they can. A good start indeed with a couple CA's! Good luck with them. Sorry, can't help you on the loader, but maybe one of the family here can ID it for ya..... ![]() Steve@B&B bb-customcircuits.com |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Posted: 26 Jul 2023 at 9:49pm |
Welcome Mike, you got the picture thing down pat quickly. Good instructions Steve!
CA’s are great little tractors with a lot of power for its size. Just in case you are unaware the lever on the right is a hand clutch, pull it back and it will stop movement of the tractor but the pto will continue to turn allowing continuous operation of equipment like mowers, small combines, balers Slowly release it to get moving again. Rob Edited by AC720Man - 26 Jul 2023 at 9:50pm |
Mikez
Posted: 26 Jul 2023 at 10:21pm |
Welcome to the forum
Posted: 27 Jul 2023 at 7:55am |
somebody did a nice job on that CA... When they put the B front end on it, they used the B steering box instead of cobbling up something... And you got the hitch AND a 3 point.. Nice tractor !
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 27 Jul 2023 at 9:06am |
From one Mike to another, welcome to the forum! CA's are great little machines.
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 27 Jul 2023 at 9:27am |
Welcome from someone in the LP lol!!!
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Posted: 27 Jul 2023 at 10:36am |
Mike welcome to the forum. I have a CA narrow front and can't believe what it can do.
I had a loader on a WD that looked just like the one you have and was told it was a Freeman. Not for sure so maybe someone can confirm.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
UPBUSHMIKE
Posted: 27 Jul 2023 at 2:35pm |
I just finished plumbing the hydraulics with all new high pressure hoses. For now I just flipped the remote port around to face forward. Though it moves slow, its leaps and bounds over moving material with a shovel and wheelbarrow! Eventually, Ill make up a nice front mounted live pump.
Posted: 27 Jul 2023 at 2:51pm |
if your loading a truck you need faster cycle time... If your lifting a load and holding it.. or carry a distance... the Slow lift speed is not a problem .. ?? Very nice unit.
Edited by steve(ill) - 27 Jul 2023 at 3:05pm |
UPBUSHMIKE
Posted: 27 Jul 2023 at 4:32pm |
Speed is not in my vocabulary.
. At 63yo Ive made it a point to slow everything down including running to town……Life at 18mph is grand! |
Brian G. NY
That loader appears to be an A-C 100A or 100B loader built to fit the CA, D-10 and D-12 tractors.
UPBUSHMIKE
Posted: 27 Jul 2023 at 6:23pm |
Thanx Brian,
I was hoping it was an Allis loader. Ill see if I can find a reference online.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8409 |
Posted: 27 Jul 2023 at 8:52pm |
Welcome Mike.
My Father grew up around Allis tractors(CA & WD). Dad always claimed a CA was a perfect match for a Roto-Baler. Lots a great knowledge on this site, explore the other forums here. There is a ‘politics’ forum, contact the site admin., or one of the moderator’s they will let you know how to gain access. |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 27 Jul 2023 at 9:39pm |
Welcome Mike! The CA is one tough little tractor! Extremely easy to work on and a lot of fun to drive and work with. You've gotten a good start on the Orange Flu Bug.... It only gets worse. If you can't find an answer on the net, or on here doing a search, just ASK. And as was said, there are no dumb questions. But sometimes the answers get kind of out in left field sometimes. It's ALL in fun (except the political forum - it's DEADLY in there!!)
