D17 wiring clips |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Jun 2023 at 10:31pm |
Anyone have a source for the clips that hold the wiring in place around the transmission housing and rear lights for a early D17? They are NLA from AGCO. Mine are either broken or missing.
Thanks Rob Edited by AC720Man - 26 Jun 2023 at 10:31pm |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Charlie
Thanks Charlie, was hoping to stay with factory style but I may have to go that route. Maybe some NOS out there somewhere?
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8732 |
Looked quick and there’s multiple clip part numbers. Which ones you need
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
Rob, I have some of the harness holddowns that are still on the old OEM setup harnesses. I'm not sure which ones you need, but if you send me a pic and I have the ones you need on the old harnesses, I'll carefully remove them and you can have em'. I also have bins of different size aftermarket ones that I use when I have a vehicle in the big shop that I'm wiring like what Charlie sent ya. Steve@B&B
Steve I hope you can make out the clip. I will count how many there are when I get on AGCO parts book tonight. Basically looking for those clips, fender wiring clips, and the ones that attach to the rear remote line that the wiring loom follows to get the rear lighting. I realize I can use tie wraps but I would like to have originals if possible. If you have an old harness that still has the clips to feed the front of the tractor that would be great to!
Thanks buddy Edited by AC720Man - 27 Jun 2023 at 5:28pm |
Looks like part # 70229498.
Need 4 for the rear transmission housing. |
I don’t have any of that number available.
Hey Rob! How bout' somethin' like this? All these clamps were off of the same D19 harness that I use as a pattern. I have other OEM harnesses with clips on them as well. I'd Have to dig out the old patterns, but I never bothered to take the clamps off.... |
The large clamp closest was at the back of the dash. The next one was sorta in the middle. The next one was off the engine area, and the last one was at the Generator. HTH Steve@B&B
Thanks Steve for looking for me. I still have a little time before I can borrow the paint room since there is a broken down Blue tractor in it waiting for fancy injectors! I will give you a call.
Thanks Rob |
