Pusher Bolts |
Page 12> |
PDehring ![]() Bronze Level ![]() ![]() Joined: 06 Jun 2018 Location: Central MI Points: 96 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Aug 2022 at 9:46am |
I borrowed a set of 7/8"-12 pusher bolts for a 220 but found my wedges are 7/8"-9, which is a standard UNC thread. I have another set of wedges for the 220 and they are 7/8"-12. I didn't think AC used standard thread sizes on the wedges/pusher bolts.
Anyone know why there is a difference or come across this before?
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22049 |
Never ran into that before. Maybe (and that means maybe) very early 220's were different ??? or did someone run a tap thru the bushings changing them ??
12 pitch would have more pushing power than 9 pitch.
Edited by DrAllis - 09 Aug 2022 at 10:40am |
They were originally cut as 9tpi as they are clean threads. A standard 7/8" bolt runs right in. Its a 1970 model so not an early model but maybe they got switched out at some point?...
Edited by PDehring - 10 Aug 2022 at 8:05am |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24731 |
OK, now I'm REAL curious... WHAT are 'pusher ' bolts ? I need to expand my collection of trivia ( like 113355, 355/113 = PI )
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
Jay,they are used to push the wheel hub off the axle wedge. Wedge has threads,hub has tapered hole bottom to match end of pusher bolt and leading inch plus of bolt has smaller diameter with no threads. Have been pictures of them on forum before
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88237 |
thank steve, YIKES !! $50 EACH !!!!
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12227 |
113355, 355/113 = PI Huh? Assuming your comma is a decimal point, I get 1003.144735...) If your comma not a decimal, then 1000 x above. Guess you could say (113355, 355/113) - 1000 = PI ??? Then, you aren't even good to the 3rd decimal point. Not even close to the ballparks I play in in my industry. Shoot, good ol' 22/7 is closer than yours. 3.142857
355/113 = 3.1415 ....... dont know what the 113355 is for.
ok... its to memorize 11...33....55....
Memorize. . . . .I didn't know you spoke Canadian. Memorize, I thought mnemonic tricks were supposed to be easier to memorize than the thing itself?
But I will give it credit, it IS close enough for my playground, though "just".
oh, its closer than that...
PI = 3.141592653589793238 355/113 = 3.14159292
Edited by steve(ill) - 10 Aug 2022 at 2:54pm |
yes, 355/113 just real easy to remember it a 113355.... it's the closest any pair of 3 digit integers can get to PI.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3951 |
Did someone say pie? I'd like blueberry please.
Pusher bolts in action ![]() |
And being done the right way with the axle keyway at 12 o'clock high.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8733 |
How many do you need to do a wheel. I understand how they work, just wondering. Do you do both wedges or one at a time.
All four. Tighten each in succession until POP it is loose. I kept one regular bolt in loose so the wheel would not fall away from the hub.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Which model Allis-Chalmers tractor first used this?
How do you know how close my playground is? You don't. We must use leads and helix angles calculated to .0000x. So, the "9" above. So like I said, barely close enough.
Clear as mud. If it works for you, good for you. Personally, I can remember that fraction easier than your code for it. I just use the Pi button on the calculator, or the Pi command/ constant in Excel, or programming language. Then ya know you're good.
![]() Edited by Tbone95 - 11 Aug 2022 at 7:18am |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
This must be why I've seen so many impact marks on older tractor hubs at work.
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5603 |
??? D19 ???
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4545 |
I'll have some 7/8" -12 pusher bolts for the two piece wedge available at Baraboo. Will be driving around in an orange golf cart with two white racing stripes and an A-C logo on front.
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
I only have 3, will that work? or do I need 1 more?
need to put an axle seal in the 7060,, and would like to move the centers 'in' few inches too and find $80.00 for a 7/8"X12 tap.....
Edited by Michael V (NM) - 14 Aug 2022 at 11:10am |
I lost track of the mission here. Are you in need of a set of custom 7/8"-9 jack bolts? I would buy 7/8-9x10" long bolts (grade 5 about $20 each) and a 7/8-9 threading die. Need to turn down the ends (lathe work). I assume 10" is long enough? I own a lathe, so that is the way I would go. I make enough things out of common bolts. Always cheaper than purchasing metal stock from McMasters and such. Another way would be 7/8-9 all-thread rod and weld a hex nut on the end, plus the lathe work. However I don't know the "grade" of the all-thread rod. But the cheap way out. |
Grade 5 quality for an axle wedge pusher bolt would be a bad idea. A 7060 requires FOUR pusher bolts if the wedges haven't been loosened in years. Three is useless. Sometimes if the wedges aren't terribly rusty, two will get the job done, but it's kind of rare.
The coarser thread pitch is going to make it harder too if they're really stuck. It's the mechanical equivalent of pushing a heavy load up a steeper incline. But, we don't know how tough they're going to be to move.
I haven't seen it mentioned here, and maybe I was advised incorrectly years ago when I first got my 7045. But I was advised to heavily and sequentially tighten the bolts, then whack the end of the axle with a sledge a few times, tighten, whack, repeat. My right side which had probably been moved a few times may not have needed that. The left however took me two more days, I'm pretty sure they would never have come loose without that shock/ vibration.
I searched in the Knowledge Base forum but figured it would be useful to clarify/list the sizes of pusher bolts for what models they are used for. Is the following correct?
3/4"-10 bolts are for models D19, D21, 190, 200 and 7000 7/8"-12 bolts are for models 210, 220, 7010-7080, and 8010-8070. |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5111 |
yes, 7/8 would also cover the 4wd's, 7580, 8550, 4W220, 4W305. Easy to tell just by looking at the hub, if it's a triangle with three bolts, it's the smaller D19-7000 style. Remember some 7010, and possibly 7020's had a lower cost wedge with just 2 bolts on each half, but still the bigger HD style. Making your own out of grade 5 bolts would not work, anyone who has actually done this job knows, you need to spend the money and buy the right bolts and tap to avoid more difficulty.
Nice info. Where do the 6000 fall in on the list.
Ed are you saying tap the threads first. Edited by Mikez - 15 Aug 2022 at 11:13am |
Page 12> |
