Snap Coupler Compatibility
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler Compatibility
    Posted: 29 Apr 2023 at 10:12am
With what other A-C tractors (more "modern" than the WD45) will snap couple implements for a WD45 be compatible? Sadly due to a fall in November 2021 that rendered me totally paralyzed from the neck down (surgeries and, literally, a multitude of miracles now have me doing terrific upper body, low back/buttocks & legs very slow to return), I have to sell my WD45. I expect you guys can picture why, and also what I mean by "more modern" because I can climb steps from front/side but not so much for getting on up over the back. I have a guy that wants just the tractor and loader but not the 3-14 plows or other snap coupler equipment. I do want to keep those implements since they work great with the WD45, so I'm wondering what other A-Cs they'd fit. Otherwise I'll probably put them up for sale locally and look for a cab tractor.
Thanks in advance,
 - Tim
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 10:58am
I have 3 D-14s and they all hookup to the SC 3-14 plow ,SC Oxnard rear blade, C subsoiler as well as the 3PH tiller that's bolted to a SC<>3PH adapter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 6:44pm
There are some differences in length of the tongues for WD's to D series, but in general you can interchange them, give or take a few inches on the tongue...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 7:19am
If you are replacing a WD-45, you don't want a D-14 or D-15. You want/need a D-17 or bigger and all the snap coupler implements you have will interchange to to the larger tractor. (D17/19 or 190/190XT snap coupler models)
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 1:45am
Sent you a PM
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2023 at 11:33pm
Put steps on the 45, I know DJ Tractor has them…
Been meaning to make a set for my 45, even as a young guy…
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 12:46am
Get yourself an early D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 2:03pm
Thanks, guys! Been a little busy expanding my vineyard at the house. That plus all the other usual springtime chores and - not on here much. I also appreciate the private messages, if I can wrangle it I'll make steps per Dirt Farmer's plans so I can keep the tractor. Fired it up the other day and it's developed a skip, shut it down so as to not make anything worse. Time for a tune up!
