Field cultivator??? |
Mikez
Topic: Field cultivator???Posted: 12 Mar 2023 at 8:21pm |
I’d like to get an allis or DA field cultivator. I don’t do a lot of field work so don’t need anything huge. I have an 8050 to pull with but my question is what would be the limit for 200 or 6080. Didn’t want to get something only one horse can pull. Or dumb question, if you had wider one that wings folded up. Can you operate cultivator with it folded or would it damage them. Do I want a 1200,1300 or 1400. I want to get smooth field for hay field.
Thanks Edited by Mikez - 12 Mar 2023 at 8:27pm |
Posted: 12 Mar 2023 at 8:47pm |
Find a 1200 that is less than 20 ft wide and all the tractors will pull it wings down.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 13 Mar 2023 at 7:11am |
Ideally you want a DMI or even a CIH (the new CIH are red DMI’s) on a limited basis I’ve pulled my 24 foot 4600 with my 6080 on limited occasions with the wings folded up haven’t tried the Tigermate on anything orange yet. Without a crumbler the 24 foot was perfect for the 8030 and 24 foot and a crumbler would be about right for a 8050. Keep in mind trip force of the shanks plays into what you can pull newer cultivators have higher trip force witch is good.
orangereborn
Posted: 14 Mar 2023 at 12:42am |
MIKE....Meet your new friend***
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3672 |
Posted: 14 Mar 2023 at 7:53am |
The AC 1200 is a good FC. For other smaller FCs, I’ve also had good results with the similar aged Glencoe FC. It’s 3pt, 12’ wide, 3 rows of shovels, & mounted spring teeth harrow.
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1261 |
Posted: 14 Mar 2023 at 8:44am |
If you have any residue, heavy bean stubble, make sure the one you get can handle it.
I have a Will Rich and a 4800 Caseih, both will handle residue pretty well, the harrow will be the problem area. the 4800 has 5 rows of shanks, the Will Rich has 4 rows of shanks. Both are 24 foot, 8050 handles both easily
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 107 |
Posted: 14 Mar 2023 at 9:32am |
Depends on what you're conditions are, AC field cultivators become a big dump rake when you're dealing with residue and stalks. We had a 20ft 1200 last year, 6080 was working hard to pull it and 8050 played with it.
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25296 |
Posted: 14 Mar 2023 at 9:47am |
My gut says running with the wings up is a bad idea, lotta bouncing around compared to running down a smooth road........??????
Posted: 14 Mar 2023 at 9:49am |
There is a helluva difference between 2 inch sweeps and 7 inch sweeps as far as residue flowing thru the 6 inch spaced shanks. Also a big diff in how hard they pull.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12431 |
Posted: 14 Mar 2023 at 10:56am |
Meh. . . I did it once when my Allils was down. Not that bad, they're built pretty tough. And what is this "smooth road" of which you speak?
johnea4
Posted: 14 Mar 2023 at 2:25pm |
I have a 24' Allis 1200 with folding wings for sale that i used behind a 190xt with no problems. Like has been mentioned, they plug up quick in trash, but it worked pretty good behind a disk. Where are you located? It's in central Indiana and is for sale pretty cheap, needs new hoses for the wing cylinders and new tires on the front depth gage wheels.
John
Mikez
Posted: 14 Mar 2023 at 9:14pm |
Thanks guys.
acplowboy45
Joined: 09 May 2013 Location: connersville IN Points: 266 |
Posted: 15 Mar 2023 at 1:30pm |
So what size shovels is everyone running.
Michael (WI)
Joined: 12 Sep 2009 Location: Larrabee, WI Points: 815 |
Posted: 15 Mar 2023 at 1:53pm |
I used a maxed out for width 1200 with coil tine levelers behind a 6080 fwa with duals. I recently used a 25' 1300 without levelers behind my 8030 fwa with duals, both became rakes in heavy trash so I recently upgraded to a 21' 1400 with Willrich spike tooth levelers to clear the trash. I should mention I made sure the 1400 had the narrower shank spacing option of 7". Thankfully someone repainted the DA from green to orange. The 1300
![]() Edited by Michael (WI) - 15 Mar 2023 at 2:35pm |
Michael (WI)
Posted: 15 Mar 2023 at 2:05pm |
The 1400
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 17 Mar 2023 at 4:42pm |
I have two 1400 cultivators and retired my 1300 after pulling it for 42 years. Narrowest 1400 is 24' so may be a one horse only for you but will handle the trash many times better than a 12 or 1300.
Mikez
Posted: 17 Mar 2023 at 9:02pm |
Oh and I’m in New York
Mikez
Posted: 17 Mar 2023 at 9:36pm |
What is dale have in his pictures, 1200
