D15-2 alternator bracket |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2592 |
Topic: D15-2 alternator bracketPosted: 16 Mar 2023 at 2:45pm |
Howdy all, am getting ready to convert Diamond Girl to negative ground with an alternator. Whomever has already done this will a new bracket be needed or will the old one work? Same question for our 17-3. Mini Denso alt. Thanks. These are my last 2 of several conversions. Dana
Blue Skies and Tail Winds
Dana |
Stan R
Posted: 16 Mar 2023 at 3:40pm |
I cobble welded our D-17 series 4 bracket when we went the alternator conversion a few years ago.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34416 |
Posted: 16 Mar 2023 at 3:50pm |
Maybe look for a 170 bracket for the d17. One of the D17 's here had a ready-rod through the old gen bracket and then had to short flat irons on the ready rod with nuts on each side of them and then the upper holes of the flat irons were for the alternator. It was converted back in the late '70s.
Posted: 16 Mar 2023 at 4:52pm |
Use a mini-sized alternator instead of an old and big Delco.
captaindana
Posted: 16 Mar 2023 at 5:18pm |
Yes thanks. Doc I bought a bundle of the mini Denso. The 15/2 is what I plow snow with so just trying to get an heads up, cause it’s still March and I can’t chance being without her for only a couples days🤔
Dana |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1867 |
Posted: 17 Mar 2023 at 9:30am |
Like doc says, with the mini I took my original generator bracket and cut/welded it to hold the alternator.
coggonobrien
Posted: 17 Mar 2023 at 9:33am |
coggonobrien
Posted: 17 Mar 2023 at 9:35am |
Posted: 17 Mar 2023 at 10:25am |
Be sure to use a 1/2" width belt, which is wider than original. The OEM belt is like a rubber band and just doesn't last long or stay tight because it slips all the time on the fan pulley. The 1/2' belt sits high in the pulley but works into place nicely WITHOUT slipping and needing adjustment all the time.
captaindana
Posted: 17 Mar 2023 at 12:39pm |
Thanks you guys!
Dana |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4185 |
Posted: 17 Mar 2023 at 12:42pm |
I really like the looks of that mini-alternator. Since I have a couple of Delco's on the shelf that have already been rebuilt they will probably go on before I buy new.
Posted: 17 Mar 2023 at 7:57pm |
The mini-alternator helped with the installation of the belt driven new "live" hydraulic pump.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5190 |
Posted: 18 Mar 2023 at 6:50am |
Any alternator bracket that would work on a B,C or CA would also work on a D10/12/14/15.
captaindana
Posted: 18 Mar 2023 at 7:27pm |
Wow thanks Steveill and all! This was my seventh alternator conversion since mid January and it was a breeze. Charges perfectly. Tomorrow morn check tires, grease zerks, and put loader back on. I get my L306 delivered Monday so that’s the next restro. After that the Allis rear blade gets restro’d, then my last alt conversion (#8) on the 17 III. Cheers. Dana
Dana |
