g2800 lp |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3820 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jan 2023 at 9:44am |
going to go look at a tractor for parts 190 xt with a g2800 lp so i do not know any thing about the enginge but it looks like a lot higher compression (on tractor data) mostly interested in the engine for a puller other parts on the tractor have been robbed what is the crankshaft nut size so i can take a wrench with to turn the engine over
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21490 |
1 5/16" wrench I think.
so is this a good engine i did not even know that it exsisted untill i seen the tractor last summer
They were fine but I'm sure suffered the same problem the regular gas models did.......the piston top could break off and the skirt was left going up and down in the sleeve. I don't believe there are any piston/sleeve kits available anymore for gas and surely not LPgas. If you want high compression for a puller, use diesel pistons and just mill open the bowl some more and get 12 or 13 to 1 compression. LPgas is only 9.3 to 1, I think.
I might have a set if 4.1/8 forged pistons for it. Have a block bored for 226 AC sleeves. Call 660 663 9173. MACK
groundhog55 ![]() Silver Level ![]() ![]() Joined: 26 Apr 2011 Location: nw in Points: 217 |
I think that I know were there is a set of piston and sleeves for that engine.
could this engine go in place of the engine in a wd45d or d 17d or d19 and use as a farm tractor . 4 1/8 pistons and sleeves what c.i. does that come up to? might have to start a new post in the pulling section
DON G ![]() Silver Level Access ![]() ![]() Joined: 14 Feb 2014 Location: Lowpoint, IL Points: 407 |
I had one. 265ci.
![]() Edited by DON G - 26 Jan 2023 at 7:14pm |
A 265 cube engine was the G-2500 used in the 180 and 190, not a 190XT gas. Was only 75 HP on the 190.
4 1/8 bore makes it 340 ci. MACK
i am going to stop and look at it tomorrow i am thinking this will be puller matierel for the one pull we have a year
