WD45 steering bolster
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 steering bolster
    Posted: 19 Dec 2022 at 5:02pm
I brought my 57 WD45 into that shop to do some work on it and I noticed the bottom of the steering bolster is leaking pretty good.  It has the 4 bolt axle and there is no bolt on cover on the top like my 54 WD45 has.
Can I leave the bolster on the tractor to replace the seals on the bottom, or do I have to remove it and flip it upside down?  I don't want all the guts to fall out if I leave it on the tractor.  Many thanks!
Good time to fix up the front pivot too!
Edited by DSeries4 - 19 Dec 2022 at 5:03pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2022 at 6:57pm
Myron
Sent you a Xmas Present.
Check your email, and not under the Tree !
Gary
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2022 at 8:52pm
the 3 bolt front bolster will have the rectangular top cover, the earlier ones had a square cover and 4 bolts. the true WD45 from factory will have a 4 bolt front support and a round press in cap that can be pried out or using a chisel to tap it up and out.
  Without the repair manual here, I would say to block the tractor up,  take the wide front off, remove cover and look in and see if there's a cap screw or two on top of steering sector gear. Take them out and remove bolts underneath, maybe leave a bolt or two partially in to catch the assembly and then press shaft out of steer gear. Good luck.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2022 at 8:14am
   JC-WI
So the first 40,000 WD45's built in 1953 were not 'true WD45's' because they did not have the 4 bolt Support Plate or the round Cover Plate on top.
Not sure where you get your info from, but I rely on the Allis Parts Catalog for the facts.
      1953 at Serial WD 127,007 the so-called 45 Trans. with Curved Shifter
      1953 at Serial WD 146,607 1st WD45 and 226 Engine, Snap Coupler Drawbar
late 1954 at Serial WD 186,413 4 bolt front Plate and round Press-in Cover
G
corrected typo: 1953 to 1954, near the end ( 190992 ) of 1994 production
Lowest Diesel Serial on the Owner Registry is 201190
Edited by Gary - 21 Dec 2022 at 4:12pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2022 at 3:22pm
Serial 186,413 is late 1954 not 1953. I have 175421. it is a 1954. They were true WD45. Later ones had a couple upgrades tho - not uncommon.
Edited by Ed (Ont) - 20 Dec 2022 at 3:24pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2022 at 5:57pm
My dad bought one of the last '53 WD's, it had the pin drawer bar which was changed to a Snap-Coupler. Also the snap latches were added.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 7:43am
They went to the four bolt plate when the diesel engine was introduced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2022 at 8:33pm
Started working on tearing down this afternoon.  Spent some time working on removing the round cap on top.  I have it lifted up a bit, still more to go.  For removing the entire bolster, the universal joint needs to be disconnected from the steering shaft.  I see mine has a solid round pin keeping things together.  Any ideas how to removed the pin?  It's also under the governor - not the most accessible location!
Next question:  the manual specifies SAE 240 fluid for the bolster, however I do not see any fill plug in the top - just a grease zerk.  Very confusing!  Can someone clarify?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 6:19am
I used a pitman arm puller to drive out the pin. It took a series of small nuts stacked up as the pin pushed through. There are photos in my "Dads WD project" thread. Admittedly, I had the side frame off for better access but the whole tractor was coming apart anyway
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 6:30am
I have used John Deere cornhead grease in things that call for very heavy grease/oil that can't be found anymore. It comes in tubes that go in a grease gun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 6:33am
I would use John Deere cornhead gearbox grease only if I couldn't find Hugger cornhead gearbox grease.  There could be some kind of bad chemical reaction to Deere products being used in an A-C.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 7:03am
I totally agree with the Dr.
The last thing you want Myron is for 'Greene Blood' leaking out your new seal.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2023 at 8:33pm
More questions:
1)  What is the best way to remove the solid pin on the universal joint?  I am reluctant to use heat as I do not want to cook the grease in the U joint.
2)  What is the diameter of the hole in the U joint?  Can a regular roll pin be used when reinstalling the bolster?
3)  What is the best way to grease the universal joint?  I do not see a grease zerk on mine.
Many thanks!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 6:17am
Hi Myron
Are you sure it is a 'solid' pin and not a spring pin packed solid with rust ?
I'd try running a small drill through the middle of the pin.
I'd remove the Side Rail to have better access to the Universal.
You'll be removing the front 4 bolts and loosening the rest in order to remove the Bolster anyway.
As a last resort, if it is a solid pin, I'd drill the outer ends of the pin on the Bolster side of the Universal to weaken it, then twist the steering shaft to sheer the remaining pin.
I see replacement Universal Joints have a Grease Zerk.
Gary
https://www.amazon.com/Steering-Chalmers-Interchangeable-70224825-70224825GV/dp/B08C8YNC9Y
Pin 912855   3/8 inch
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 7:16am
Mine is also a solid pin. This was my solution. Apply pressure to pin tap the end of the pusher bolt. Rinse repeat. I stacked small nuts over the pin as progress was made
I used a flat chisel to work the cover up out of hole.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 8:59am
Wonder why Allis didn't design the Cover with a flange similar to the later Belt Pulley Delete Cover Plate.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 9:29am
Originally posted by Gary Gary wrote:
Hi Myron
Gary
Pin 912855   3/8 inch
Hi Gary, it's definitely a solid pin.  I have all the bolts holding the bolster loosened and I am planning to remove the left side frame rail so I do not have to deal with the belt pulley seal on the right side..
The existing U joint is still very good.  No slop in it, so I prefer to keep using it.  However I would like to grease it when I get everything apart.  I will take a closer look, but I don' t recall seeing a grease zerk...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2023 at 9:48am
I use a hammer and punch from bottom side on those pins.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 7:55am
I believe those pins are still available from AGCO. My NF u-joint was sloppy so I got some drill rod 1/32" bigger, reamed the hole to size. That tightened things up a lot.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 8:47am
Myron
Once you get the Universal removed, disassemble it and see if it has grease passages from the centre of the X out to the 4 bearing locations.
If not I think you are SOL as far as adding a Zerk.
But for the amount you will be driving it, I would just clean and repack.
Gary
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2023 at 9:50pm
New U- joint inserts are available for DJ’s for less than 20 bucks and they are greasable
