D12 steering shaft
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: D12 steering shaft
    Posted: 07 Dec 2022 at 8:19am
I have a D12 that needs a new steering wheel. Unfortunately, a previous owner welded the nut on the shaft. I have looked, unsuccessfully, for a new steering shaft. Suggestions?
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2022 at 8:57am
Break off the rest of the plastic, grind the weld off flush with the nut using an angle grinder, use a die grinder and carefully grind the root of the weld out, should leave enough of the threads to thread a new nut back on. If you don’t have a die grinder you can grind off the weld above the nut and split the nut with a cold chisel, then carefully clean up what weld is left above the threads with a grinder. Otherwise there’s a couple used shafts on eBay.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 6:51am
I have been checking Ebay daily. I have never seen a steering shaft for a D12. I can find them for a D14, D15 or a D17, but none for a D10 or D12. Where did you find them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 7:06am
My bad, I had d14 stuck in my mind. Could you shorten one from a d14?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 8:28am
I'd grind the nut off and take the shaft to a machine shop and have them weld a new end on it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 8:39am
I have done that on a couple B... i shortened the shaft on a couple, and have cut the top 2 inches off the shaft on one and welded a stud back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 4:24pm
I am wondering if the shaft os hollow (I don't think it is). If it was I could probably get a bolt with the right thread and put it in the lathe and turn it down to the ID of the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 4:33pm
the shaft is hollow on a "B" ... i did exactly what you said.
allis1221G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 6:46pm
I should have a shaft. 616-334-0844
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2022 at 7:18pm
Mine is a D 12 Series 3. I believe the early ones were different. Which one do you have?
Coolharts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coolharts Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 12:18pm
My D10 has the same issue, nut welded on but unlike yours, it is welded on farther down the shaft below the steering wheel opening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 12:31pm
Jon... how did they get down below to weld ??  Easy way would be the nut on top ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2023 at 4:17pm
That's a later model steering shaft with a splined end which the steering wheel sits on.  Best to find a used shaft from a D15 or 17 and shorten the opposite non-splined end.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2023 at 12:54am
Doesn't the steering wheel have a spline? If so welding a bolt will not work.
