6080 unidentified pin?
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: 6080 unidentified pin?
    Posted: 13 Nov 2022 at 6:41pm
I will snap a picture tomorrow, but wanted to post Incase someone had an idea before then.
On the right front of the engine behind the front cover kind of inline with the external thrust bearing bolt on the driver side of the engine. I can only get views of the right front of the engine in the books I have. It looks like a shiney metal pinky sized metal dowel that moves freely. It does not look to be a twisted of bolt.
I am at a loss. Any ideas?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 8:28pm
Gazingus pin...
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 8:29pm
There is dowel pins on both sides of block In front. If it is loose, you will have trouble. It will work gasket out, then start leaking oil behind inj. pump, and will eventually twist inj. pump shaft off. Will also crack oil pan.
Fix is new front plate or rebuild yours, new dowel pins, and hope new pins fit tight in block. Leave front weights off, don't use a front loader, and be careful crossing ditches and terraces at angles.                        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 4:46pm
Here is a picture.
I assume this is the front cover dowel?
If so is there somewhere I can get an idea how to rebuild the front cover? What if it does not fit snuggly in the block? This is a major issue any non-rebuild fixes suitable?
Thanks,
Stephen
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 8:01pm
The answer to this is probably no, but I figure I'll ask.
Can I put some locktite in this dowel and push into place from the fuel injector pump side?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 8:48pm
You can, but it won't stay. Fix it now or spend more later.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 5:37am
Makes sense. Any internet resources you would suggest ?
I have rebuilt a Volkswagen engine, but not a tractor engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 6:09am
agree best to properly fix it
but......
 after to clean and locktite it in,
is there some way to  add a 'bracket ,bar, or ??' to wedge the pin in and prevent it from coming out ? maybe a threaded rod, 2 nuts to force pin back and keep it there ?
At least if mechanically secured, it'd buy you some time to research how the 'proper' fix is done. I'm guessing a LOT of stuff HAS to be removed to do it right though.....
One of those have to see it to figure out how
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 6:39am
If there are no serious oil leaks in the general area (oil pan/timing cover/front plate to block) pound it back in just below flush. Then, lightly peen the blocks hole to keep it from working back out. Keep all timing cover bolts tight, especially the bolts on the external thrust bearing. If this doesn't last, then you'll have to go deeper.   I thought this problem was addressed some months ago ??
Edited by DrAllis - 15 Nov 2022 at 6:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 2:40pm
Dr. Allis:
I did not report back about the oil leaks. I also didn't see this pin until last weekend.
What I did:
I tighted all front cover bolts to spec., and all oil pan bolts to spec. The engine does not leak at all.
I'll see what I can do. Thank you very much for your reply.
This page was generated in 0.052 seconds.
