8070 and 3000 plow
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: 8070 and 3000 plow
    Posted: 03 Nov 2022 at 8:23pm
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2022 at 8:30pm
Hope you make a video of her tearing up some ground. She looks ready to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2022 at 9:32pm
My nephew got some good video. Can you upload a video file to the forum?
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 10:35am
I bet your nephew can figure it out. I think you put it on YouTube and then post the link here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 10:52am
Thanks ac720man. Thats what he's working on. We should have it by monday
1984 80780
1957 D14
616 tractor
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 11:00am
Looking forward to seeing it
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 8:33pm
Bad news on the 8070. Started it today and had a tapping in the bottom end.
Think I might have spun a rod bearing. Going to get the pan off in the next couple days and see whats going on
1984 80780
1957 D14
616 tractor
BlueBandit17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlueBandit17 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 10:27pm
8070NC's nephew here - I finally got the video uploaded. Bear with me, I am new to the forum and Youtube uploading as well!
Allis Chalmers 8070 and 3000 Plow:
Let me know if the link does not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2022 at 11:14pm
Welcome to the forum nephew. Video worked good.
Sorry to hear of the noise 8070
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 3:29am
Just posting a cropped pic of 8070 with 3000 plow, so it is on the page.
 Sorry to hear that the 8070 has noise of trouble... Hope nothing serious.
https://www.allischalmers.com/forum/uploads/242/8070_with_3000_plow.jpg It sure is a thing of beauty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 8:03am
Thank you for the copmpliments fellows. Its a labor of love but from a practical standpoint its cheaper and simpler with this equipment than newer
1984 80780
1957 D14
616 tractor
Gleanermanl2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gleanermanl2 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 8:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gleanermanl2 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 8:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 9:22am
Awesome. Somehow my plow is different than those plows. The front wheel on my plow is directly outside the tractor wheel so i cant run dual wheels. Looks like the tube the hitch is attached to om my plow is shorter
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 9:26am
Ive got a full set of coulters but they are the rubber spring type and they have all come apart and i havent decided how to fix them
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 9:27am
Anybody got any suggestions
1984 80780
1957 D14
616 tractor
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 10:42am
great vid, looks bouncy! Sorry to hear about the engine issue! Dang the luck man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 11:10am
I was bouncy Ed. I had methonol put in the tired that morning and they put too much air in them. I didnt take time to let them down cause it would need to jack it up to get the valve stems to thr top. Ill do it while its in the shop to see about the bearings. Ill let you know what i find
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gleanermanl2 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 4:56pm
I don't think these plows were designed to be pulled with duals on the tractor. These are pretty old plows and I think they probably came out in the late 60's. Mine is a 3000 plow as well. I cant hardly turn right at all with the duals on but in a big field I can pull it with large headlands. Next time I pull it I will yank the duals off. As far as the colters go. I have no recommendation on repair of them. Mine are not the rubber mounted type. I would suggest finding a scrap plow and just robbing some others off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2022 at 7:14pm
Ive got lathes snd milling machines so I thought id make the coulters into a spring type ive got too much to do thats more important. Maybe a dead of winter project
1984 80780
1957 D14
616 tractor
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2022 at 8:59pm
I have the same 7 furrow 3000 plow but with hydraulic resets. Hope to try it on my 220 fwd . I think they are a very rare plow.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 6:50am
7 bottoms with a 220?  Wow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 8:11am
[QUOTE=Calvin Schmidt]I have the same 7 furrow 3000 plow but with hydraulic resets. Hope to try it on my 220 fwd . I think they are a very rare plow.
7 bottoms with a 220?  Wow.  Slow and steady wins the race !
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 10:34am
My plow is hydraulic reset.
Dangdest thing i ever saw
Ive seen places in the field where a bottom had tripped and reset but i never felt it in the tractor
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 11:17am
Back in "the day", the D-21 was touted as a 7-bottom tractor and the mighty 220 Land Handler was 8-bottoms.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 3:13pm
Had a neighbor buy new 220 with         8 bottom reset plow. used for a few years, then got a 440 with 3 point, used plow with that for several years.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2022 at 7:40pm
I have a 7 bottom toggle trip and one with hydraulic reset.  My grandpa bought the toggle trip plow new and we used to pull it with a 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2022 at 7:17pm
Did you figure out what was going on in the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2022 at 8:17pm
I believe its fine. I pulled the #2 rod cap and the bearing is fine. Im going to put a set of rod bearings in while im in it.
Ill know for sure next week when the bearings get here
1984 80780
1957 D14
616 tractor
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2022 at 8:51pm
I would replace the harmonic balancer also.
This page was generated in 0.045 seconds.
