Allis 6080 cork gaskets - retighten? And dipstick
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: Allis 6080 cork gaskets - retighten? And dipstick
    Posted: 25 Sep 2022 at 8:11pm
I am finishing a rebuild that was started by someone else (they unfortunatly passed before all the work was done). I have been torquing bolts where oil has been leaking to spec.
Do the cork gaskets "seat", and require retorqing? Specifically the valve cover, oil pan, and front cover. I torqued all of these to spec., and most of the oil leaks stopped. I noticed a little oil around the pan while I was getting the stearing cylendar off.
My question is should I keep retorqing these? Do cork gaskets "seat"?
My second question is is there a good after market heat to add to this tractor to help cold starting. Oil dipstick heater, or something else? Just got some electricity near the machine.
Thanks for the help!
Thanks all!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 8:17pm
Must be a cheep gasket set. Only cork gasket is valve cover.
Get bolt set for 8000 series valve cover and torque once.                        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 8:41pm
Thanks Mack. I'll see what I can do. Any thoughts on cold cranking after market heater?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 9:08pm
Can’t you get a factory style block heater
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 5:40am
Factory block heater just above the starter. Look for the cord.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 9:21pm
Cord unplugs so it can be replaced, it may have been removed if your not seeing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 10:03pm
I don't see the heater at all. Where would I get one of these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 10:07am
It is located directly above the starter, a "cats-eye" shaped plate bolted to the engines block. It has a 1/2" tube welded to it that crosses over behind the block to the oil filter area on the other side. If there is no electrical connection on the cats-eye plate, you don't have a block heater. AGCO is the only place I know of to get one, if they still have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 2:45pm
It not priced in parts book. Think there was talk here while back NLA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2022 at 6:54pm
Theres a place in PA- Country Side Tractor , or something like that- has a kit for this - or get one for the One Eighty, 190 , etc then drill out a passage toward the back and hose it to the oil cooler with fittings etc
Edited by DougG - 29 Sep 2022 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 11:33am
Yes with some ingenuity you cake "make" one
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2022 at 4:49pm
Understood. I am talking to the folks in PA. See what we can figure out.
