D14 Gears jumping out
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Gears jumping out
    Posted: 21 Sep 2022 at 7:16am
On my D14, I had the problem of the 3rd gear jumping. I modified this by shifting the lockout by 0.1". This solved the problem. But now downhill I have a noise that sounds like a friction noise or a slight snagging of a gear pinion.
How to fix this problem and what is the origin?
This jumping out problem is common to the D10, D12, D14, ED40, and other models such as the 180 series
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:20am
Only in third gear going downhill ?? or makes the noise in any other gear too ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:22am
it is only in third gear , after making the modification to fix jumping out problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:25am
So, you have to make a management decision. Leave it the way it is (staying in gear going downhill with a noise) or change it back to jumping out of gear and no noise. Kind of a no-brainer for me. Make sure it's full of trans oil to keep that shift fork well lubed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:29am
OK . Do you know if there a stronger spring shift rod detent to put
Original is Ref 70207770
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 7:44am
I always use a 70229458 spring from a D-17 hand clutch and shove it inside the existing detent spring. I also make a second detent utilizing the neutral spring/ball so two properly timed detents lock it into gear.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:45am
When you moved the detent on 3rd gear shift rail, you prolly moved it enough so 3rd gear meshes with or is bumping the reverse idler gear.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 11:59am
Which on D-15's is a very common noise when running third gear. Kind of a growling noise and only when in third. D-14's that reverse gear is a little narrower so it might be just kissing it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 12:28pm
So , if it is bumping the reverse idler gear.
Can I think that this noise should not worry me and does not present any risk for the gearbox and the various gears?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2022 at 12:42pm
I think you'll be fine.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2022 at 7:51am
I moved mine .090" about 15 years ago with no noise or other problems. I have done others with no problems. Sounds like it's going a little too far.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
This page was generated in 0.227 seconds.
