Gleaner chopper question
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner chopper question
    Posted: 14 Jul 2022 at 9:01pm
Hello all, putting new stationary teeth (concave) in my L3's chopper, fresh from AGCO they seem dull, but definitely better than the old ones.
Should I sharpen these before I put them in? I'm guessing they should go in as is but thought I'd ask. Thanks.
BTW flail blades are good, nice flat edges
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 10:07pm
I would say just use them that way, more medal to wear off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 11:28am
The knives do the cutting. They need something to whack against. The factory concave is fine as is. I doubt you could tell the difference if you sharpen them.
Edited by SteveM C/IL - 15 Jul 2022 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2022 at 8:24pm
Ok thanks, other forums suggested that the spinning flails should have a square dull edge and these concave teeth need an edge on them.
One guy said he sharpened the flails and it made it worse.
It works ok now but had several missing teeth, $16~ a piece from AGCO in Canada
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2022 at 10:49am
The edge of the flails isn't that picky either. What you have to pay attention to is the corners getting rounded off. Round corners won't grab damp straw. Next thing you know you are baling the back end and wrecking walkers and cranks.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 11:11pm
They sharpen them in the rotary machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2022 at 10:30am
False blanket statement. My 97 R62 is just like the conventionals only blades are some bigger. Have seen S? series with fine cut chopper had sharp knifes.
