C and CA Weight
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: C and CA Weight
    Posted: 01 Jun 2022 at 10:26am
Approximately how much would a narrow front C and a narrow front CA weight?  I was wondering if I could haul both of them on my dual axle car trailer.  Looking at going about 70 miles.  Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Dale (Stonelick) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale (Stonelick) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 10:44am
As per tractordata.com:
CA= 2835#
C =  2500#
B =  2060#
1951 CA - 1944 C - 1949 B - Kubota M6800
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 5:39pm
There are a lot of variables; weights, calcium in tires, etc.
I know several people that pull CA's in the 2500 lb. class (includes the driver).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 7:12pm
So, do you think a C and CA without fluid in the tires can ride ok on a car trailer at the same time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 7:58pm
Again, there are variables.
What is the GVW of your trailer and what will you be pulling the trailer with? If your trailer has a load capacity of 5000 lbs. or more (and has tire capacity), your trailer should be adequate. Keep in mind that the GVW includes the weight of the trailer, also.
Some car trailers have only about a 3,000 lb. capacity. There should be a tag on the right front of the trailer telling the GVW of the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 8:12pm
As an example, here is a picture of my truck and trailer, getting ready to go to a show last year. The trailer has a GVW of 16,800 lbs. and weighs about 4400 lbs. empty, which means I have a capacity of about 12,400 lbs. The truck has a gooseneck/fifth wheel trailer capacity of 21,700 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2022 at 9:00pm
In Illinois , the average car hauler plate is 8,000 pounds... and the trailer would weigh about 2500 pounds so you can haul 5500 pounds of "weight"... which is a good size car or 1/2 ton pickup... YES, the  CA and C should fit as they weight about 5,000 pounds together... Back the CA on, then jackknife the front tire to one side in the middle... Pull the C on behind it and jackknife the front tire to the opposite side so you can pull on further and get the weight on the axles..
This page was generated in 0.258 seconds.
