185 brake parts??
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Topic: 185 brake parts??
    Posted: 09 May 2022 at 7:23am
Anyone have anything better then the OEM brake linings and bands for a 185?  Anyone offer Kevlar linings and if they do, do they last longer?
Not looking for the cheapest ones, tractor has a cab on it, so too much work to replace them to cheap out on the parts.
Thanks!
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 9:19am
Tribco  they are 100% kevlar i used them for years
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 11:46am
OK, Thanks.
Do you have a part number for the rivets? Tribco don't have them, which seems funny to me as the rivets are usually furnished with the linings.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 11:52am
Send Rick a message here on the forum. He has a posting in the classifieds. Re relines brake bands using excellent materials. He has good prices too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 11:56am
I never even thought about him, and unfortunately I already ordered some of the parts I need. Thanks anyway.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 2:25pm
Another option is the HD bands with metallic material, comes glued to the bands. Can see them here: https://www.ebay.com/itm/224516669514
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2022 at 7:50pm
Metal on metal ? Im sure its a differt kind - I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 6:27am
Life of the bands generally does not seem to be a problem in this application, and these bands look like new so we are only replacing one side due to a leaking brake shaft seal which was damaged the last time someone had the final drives off.
It seems like when the 190XT III or the early 200's came equipped with the new at the time metallic bands the customers complained that the brakes did not hold as well.
It looks like a JD rivet part number D1761R should work fine for riveting the Kevlar linings on the drums.
Edit to update: The JD rivets I listed above were a little short, they may of worked, but I did not get much of a crimp on them. Instead I ordered McMaster-Carr part number 97451A675 Brass hollow-end rivet, 3/16" diameter for .441-459 thickness.
Edited by pirlbeck - 18 May 2022 at 2:15pm
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 4:00pm
The material in that brake band above is not what you think it is...AGCO sold them and probably still do, but it's cheap crap and the glue that holds them to the band either isn't enough or just junk...been there and done that!   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 7:20pm
In the series 3 XT run, they used a metallic material on the bands that worked much better when they were hot, versus the old conventional rivet on material that could fade when hot. Constant turning on the fields ends with duals on the tractor was the reason for this change. But, for a chore tractor, light duty braking use, they didn't stop nearly as good. Many got changed over to the older material. This was all in response to the hydraulic brakes some of the other manufacturers had at the time. (Deere, IH, MF)
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2022 at 4:50am
Dr. Allis...Agreed...THOSE metallic brakes worked great and I even used them on my D19's I used for logging. That was a metallic material they call feramic and is great stuff! However, the material they use now that's either bonded or riveted to the band has hardly any metallic material in it...even from AGCO...been there and done that and lasts no where near as long as the original stuff...I guess that was my point. I do have to agree though about the original stuff and the heat does help it stop great, too...Rick
