Carpenters Square - what and how
Post Options Post Options   Thanks (2) Thanks(2)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Carpenters Square - what and how
    Posted: 29 Jan 2022 at 11:57am
https://www.youtube.com/watch?v=Ej1D5Bxqmjo&t=645s
Using a carpenters square - what the numbers are used for . Trueing a square
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 6:37pm
Thanks for sharing, Coke. I am definitely not on the top of my game in using squares. I picked up some good pointers from that video.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 9:40am
I learned in high school wood shop how to true a square and always check one before any project. Bet nobody that graduated in the last 20 can claim the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 10:43am
I learned ,the hard way, that my 4' level wasn't level......
addition is still standing though after 35 years....
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 11:13am
I do S this video shows quite often but I always check the square with a 3-4-5 method if I find discrepancies.
Doesn’t take much of a hump or dip in material to throw the square off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 4:58pm
Hot to bring it back to square was a tip I had not seen before , guess always felt it was a tool and would stay where needed - then seen a lot of them at garage sales = probably why - go buy a new one - give the problem to someone else .
  3/4/5 is how I squared up excavations when digging footings or a basement - set up batten board corner 3 ft back from excavation and do measurements - depth became a one person job once I bought a laser transit = way back I used a optical transit but had story pole fitted with a 60p pole barn spike to hold it while I optically shot depth.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2022 at 5:55pm
It must have been a STANLY level CryCry. Not sure when that brand took it in the diapers, but I will NEVER purchase a tool with the STANLY name on it Tongue !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2022 at 11:05pm
the combo squares is what i'm always checking, since the slider part wiggles when the nut is loosened, for short markings it's fine, but not for anything past about 2 inches.
