Gauge Wheel Tire Source?
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Gauge Wheel Tire Source?
    Posted: 29 Jan 2022 at 8:17am
Looking for a gauge wheel tire source for an Allis G Independent Gang Cultivator. Same design as the common 4" x 12" gauge wheel tire except 3" x 8".
Checked with some manufacturers, no can find.
Picture is of the common 4" x 12" tire.
Any help will be greatly appreciated.
K-Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 9:42am
These guys might be able to find it for you...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 10:01am
do you have part number
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 12:03pm
Good Question. I meant to include it.
P/N 317985
Brendan (AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan (AB) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2022 at 10:48pm
If you find a source for those tires, please post it here.  I would like to find a set for my cultivators also.
Thanks!
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 6:52am
I have considered these as replacement wheels.
Make new axle bushings from DOM 3/4" OD x 7/16" ID.
If you try that route, let me know how it works out.
K-Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 5:18pm
Still, come monday, give miller a call.
Your first link was non-specific, so I don't know which of the wheels you were considering.
You may find on new wheels, that most have a 1-1/2" hole in them, if so, then all you have to do is to find the right bearing, or something close, and bush the bolt...
A word on chinese rubber.  even new it has a shelf life of about 5 years after exposure to light of day...Wink
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 5:46pm
Tire 3" x 8"
Hub 3/4" x 3"
https://carefreewheelandtire.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2022 at 7:39pm
Close, but it looks chinese, to me.  See note, above.  That hub looks like it has the knock out bearings that are likely 1-1/2" OD.  TSC generally has these in other ID (bore) sizes, easy to change it for the right sized bearings...Wink
This page was generated in 0.227 seconds.
