Allis B Clutch adjustment
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Clutch adjustment
    Posted: 31 Dec 2021 at 1:21pm
After 5 years of use my B is in need of a clutch adjustment. I wish it would be easy like on my WD but... wondering if any of you have successfully done the adjustment through the small access hole on the B, and if so, what your tools looked like, perhaps even what size your hands are :)  I will split the tractor if no easier way exists. I'm a little surprised how little talk there seems to be on the forum about this, for how many B's are still around.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 1:49pm
Eric...Sent you a message...Rick
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 1:51pm
Are you just needing to adjust the clutch freetravel. Best I remember dad would take the cotter pin out at the pedal that held the rod and turned it a few rounds and clearance was adjusted. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 11:52pm
Thanks for the tip, that would be simple enough. If the end of the rod is visible through the inspection hole that would be helpful. I wouldn't want to run out of threads in there as I'm sure it isn't easy to get the threads started going back in. I'll check it out.
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 2:44am
Reach your hand in there , you can feel how much thread is left as you adjust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 2:18pm
Thanks... I hope I can get my hand through the hole Embarrassed
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 9:29am
I just did this on CA-2. You should be able to look in there with a flashlight and see how many threads are left. Probably won't take more than a round or two.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 7:07am
I've cut the shaft and welded in a piece before to make it longer. worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 3:17pm
Thanks everyone for your input, the more ideas the better. The task will get done one way or another. As the old saying goes "you are smart if you learn from your own experiences but smarter if you learn from other peoples' experiences".
Happy New Year everyone!
Eric
