Fuel Strainer
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Strainer
    Posted: 06 Dec 2021 at 11:06am
i bought a new fuel shutoff and strainer. the shutoff casting hole is larger than the strainer and the directions say to "shim" it to keep it tight.......
can i use JB Weld gas tank seal putty to attach the strainer?
should I use aluminum foil to keep it tight?
i thought about tapping the casting but it apears to be made of pot metal so I dont know how easy that would crack,.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2021 at 5:45pm
What tractor?  If its a D series or earlier, I always just reamed out the strainer, a little...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 9:57am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 10:13am
I worked on AC for 58 years never used one
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 12:40pm
looks like an awful small sediment bowl. What is it going on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 1:01pm
On all the AC's that I have worked on, the OEM fuel strainer was a disc, that went up on the top of the fuel outlet, inside the fuel bowl...Wink
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 4:06pm
That looks like a sediment bowl/strainer for a garden tractor.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2021 at 7:54pm
My min-mo u has the same thing on it and I also have a nos one in my fuel supply cabinet if I think of it the next time I'm in the shop I'll get a picture of it
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 8:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 3:22pm
that looks like a band-aid fix for a dirty fuel tank and will defeat the purpose of the sediment bowl to collect debris and allow it to be removed. Doesn't your sediment bowl have a cleanable/removeable screen above the bowl? It should have. That standpipe looks like it would also not allow collected/condensed water to drain into the sediment bowl to be drained off, and would cause the fuel tank to rust out in time.  I would never use something like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2021 at 4:25pm
Here a couple of pictures of the strainer, and yes it has a removable screen on top of the glass bulb and it does let the water get out into the glass bulb.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 5:37am
Personally, I would not use JB Weld or anything else that would attach the strainer screen permanently. I would prefer to have it just pressed in. I would try teflon thread tape first. If that isn't thick enough, I have used strips cut from the sides of a soda can for shims. I suppose aluminum foil would work, but it isn't very thick.
I have used this screen above the sediment bowl setup on old tractors with pretty good luck, if the tank isn't real bad. It works well to catch stuff that would eventually plug the inlet. I am assuming that stuff falls harmlessly to the bottom of the tank when the tractor is shut off.
Edited by WF owner - 17 Dec 2021 at 5:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 10:55am
I agree.  Throw that stand pipe away.  Keep your gas tank clean and you won't have any problems.  The sediment bowl is all you need.  I run sediment bowls on all of my tractors and have not had any problems.  Keep the tanks clean, use good clean fuel and you are good to go.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 1:57pm
when i got my 190 I had lots of trouble with dirt and water in the fuel. I drained the tank and remove the fuel sediment bulb assembly from the tank got another 4 gallons of fuel out of it it had a stand pipe added to the valve 3 of the additional gallons were dirty water. after removing both valves and cleaning the tank out replacied them with new valves I got from TSC so their not the greatest and putting in new fuel I havent had problemssince now when I remove the sediment bowl im actually getting the water from the bottom of the tank. the cheesy screens from TSC are ok but Ive put aircraft fuel strainer screens in most of my tractors they just happen to be the same size but the screen is part if the bowl gasket.  the older Allis screens had a metal edge binding that kept them in place in the bowl.
