fuel injector lines
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: fuel injector lines
    Posted: 26 Nov 2021 at 1:44pm
Does any one on here in or close to Indiana bend fuel injector lines.
I need new lines bent for a DC pump to fit a 7000 series engine
and need inside diameter to be 120.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 3:02pm
Scheid or FVP are my 2 go to places. Unless a 1000hp puller, .093 is what I'd use. They will need a pattern though, so send the old ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 3:43pm
There not bad to do with the right bend tool
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 7:33pm
AC used larger ID lines in the 7080  and N6 engines - seems like there was different diameter on the 8070 and late  series but the #'s have been changed to an line kit of which there are two.  Ed, do you know the 2 std  AC line ID 's ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 10:54am
210/220 are about .078", some may have been .084 like 7080/N6. Don't think any of these style engines ever had anything bigger. The old 262 like a D17/19 may have had .093". Ironically later engines went to smaller ID down to .062" in the quest to lessen smoke. Nearly all the puller lines I sell are 1/4 X .093", and a few do run 1/4 X .120.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 3:02pm
scheids did bend the lines for the dc pump on the 3500 motor but i now have a 3700 motor on it and used the dc pump since it is already turned up so as one might realize those lines wont work/fit the 3700 engine.
They made 120's for it they're just not right for a 3700 engine is all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 3:54pm
I can't imagine the lines not fitting one engine to the other with the same style pump. Are you referring to an early 3500 like original in a 210/220? I'd sure think if you had them fit that style, it would fit the later 3500 Mk2 and 3700. Post a pic. I'd think you'd have more room lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 6:37pm
The possible monkey wrench is there were just over 500 "kits" sold to convert the AC injectors to Bosch which required a different line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2021 at 8:04pm
He must be going from an early 3400/3500 engine to a 3700 (Mark II).
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 9:45am
Don't need 120 lines. Fond out they don't work on a A Pump. Bigger lines affect timing. Scheid will bend lines. Its best to bring the motor to them on a pallet! Fair Valley may have a pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 1:39pm
The 3500 motor is the original motor and it is a 71 with the dc pump.
I found A 3700 MK II engine to replace the 3500 and I don't know what year the 3700 engine is but it has a dm pump on it.It was a stationary engine.
It's basically a 7060 or 7000 series engine I think.
I put the dc pump on the 3700 engine and the 3500 lines won't fit the 3700 engine .Yes scheids can make them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2021 at 1:42pm
Oh I forgot to mention that i have no idea how to post pictures on here but can do it by cell phone to a cell number,sorry just not computer savy.
