Allis B cam bearings. |
ac55tractor
Joined: 20 Oct 2012 Location: Raymond, Maine Points: 240 |
Topic: Allis B cam bearings.Posted: 15 Nov 2021 at 8:14pm |
Hi Everyone As some of you know, I have just pulled apart the engine from my 1955 A/C B. I have an issue that I could use some guidance with. I am a machinist by trade so I tend to measure parts as I go. As I went to pull the camshaft out , I gave it a bit of a wiggle to see if there was any movement between the camshaft and the front bearing. I saw some side to side movement. The camshaft journals that ride the bearing are 1.749. That seemed acceptable . The front cam bearing inside diameter was 1.758 - 1.760. So the front cam bearing is out of round slightly by .009 - .011 and larger than the cam. That seemed a bit excessive to me so I purchased new cam bearings. I received the bearings yesterday and got the telescope gauges out and to my surprise, the inside diameter of the new bearings were .009 larger than the camshaft or 1.758. From other Allis owners that I have spoken to, Those bearings over time tend to ware their inside diameter, which in turn causes low oil pressure. I checked the numbers on the box and they check out. In my honest opinion, you would think that they would have closed up that tolerance a little bit. Any input on this would be appreciated. Thanks I am off to post another topic.
Joined: 11 Sep 2009 Location: illinois Points: 89203 |
Posted: 15 Nov 2021 at 10:02pm |
I think your bearings have too much clearance.... The cam is hollow and oil flows thru it and there are HOLES in the cam that spray or SLING oil out toward the piston and rods for lube.... The cam bearings have holes thru them to send oil to the MAINs (crank) to lube those bearings.. so YES, if the cam bearings are worn, you can leak off a little extra oil.. not suppose to effect the overall pressure, but still not a good idea... more discussion here.
Posted: 15 Nov 2021 at 10:13pm |
read the last paragraph........ |
Tom IA
Joined: 17 Sep 2009 Location: Donahue IA Points: 255 |
Posted: 16 Nov 2021 at 8:09am |
they are a press fit will be a little smaller once installed
ac55tractor
Posted: 16 Nov 2021 at 8:42am |
Thank you for the response Tom. That dawned on me last night, I checked the outside and the inside diameters on the new bearings with a micrometer and a telescope gauge. The inside and outside diameters were the oversize the same amount. They were each .008 oversize . When the bearings are installed there has to be certain amount of interference fit. So when they are pressed in, the diameters (inside and outside) should fall into tolerance. :) I will post my progress. Thanks and best to everyone. Something tells me that my new bearings are going to be okay.
ac55tractor
Posted: 17 Nov 2021 at 4:16pm |
Update: I made a stepped washer with a half inch hole in the center The diameters of the washer were roughly .015 under the outside diameter and .010 under the inside diameter of the bearing, so it was able to place it into the old bearing and not effect the bore in the block as it pulled through while remaining on center. The three bearings came right out. As much as I wanted to install at least one of the new cam bearings to measure the inside diameter and put an answer to my original question, I didn't install it. I kept looking at the block and thought that it might be best to pull the piston sleeves and clean the block inside and out before installing anything new to avoid any contamination. It may be a few days until the next update. Steve (Maine)
Posted: 17 Nov 2021 at 4:25pm |
.008 press fit in a hole ? That sounds like a lot. I thought most bushings, etc when press fit were .001 - .003 ??
ac55tractor
Posted: 17 Nov 2021 at 5:10pm |
I just measured the bore in the block for the cam bearing. There are no sings of wear or out of roundness. It was pristine. It measured 1.880. you would assume that it was standard 1.875 but it is not. I measured more than once. The outside of the new bearing measures 1.883 - 1.888. That is where I came up with the .008 oversize. It is largest where the oil hole is. All three bearings are that way. So it does have a .0055 press fit. As far as the inside diameter goes. I think the best way to get a measurement would be to install the bearing and go from there. The part numbers are correct.
ac55tractor
Posted: 17 Nov 2021 at 5:23pm |
I will clean the oil path tomorrow night and install a bearing. Then we will know for sure what the final diameter ends up being. The cam shaft measures 1.749. So the cam shaft is within spec. The tolerance between the bearing and the shaft is .002 - .004. If it is any larger, the new cam bearings were manufactured oversize and I will probably be out of luck in returning an installed bearing. |
ac55tractor
Thanks(1)
Posted: 17 Nov 2021 at 9:38pm |
I just put an end to all of this. I am returning these bearings. I did not pay a lot for them. Maybe that's why they are out of round and oversize. I just ordered some real camshaft bearings Thanks for your patients with me. I am not inexperienced, I am only a first timer with this type of engine. Steve (Maine)
Posted: 17 Nov 2021 at 9:50pm |
ac55tractor
Posted: 24 Dec 2021 at 5:07pm |
I got the new camshaft bearings last week and installed them. I made a step washer on my mini mill and used assembly lube to install them. I had to watch to make sure that they went in straight. Everything went in just fine.
ac55tractor
Posted: 24 Dec 2021 at 5:08pm |
Posted: 24 Dec 2021 at 5:18pm |
did the bearing have lube hole, or you had to drill ?
ac55tractor
Posted: 24 Dec 2021 at 5:44pm |
Yes, It had the hole in the bearing. After got the first one in, I said
to myself, I wonder how many people get these holes to line up?
Clearly, I didn't. I got half a hole. My first thought was I could use a
long 1/4 inch drill and open the hole. That idea lasted about 5
seconds. I knew that I would just rip the bearing apart or break the end
of my drill bit. I used a #3 center drill 4 inches long. I went through
the hole in the main bearing to the cam bearing. I touched the cam
bearing with the tip of the center dill and slowly went through. Now
there is a straight shot hole to the bearing. Because of the way the
drill is designed it did not grab the cam bearing. It only created a
slight burr. It was nothing compared to the burr that the standard 1/4
drill would have left. I removed the burr with a 3 sided burr knife.
ac55tractor
Posted: 24 Dec 2021 at 5:45pm |
ac55tractor
Posted: 24 Dec 2021 at 5:46pm |
This is my mini mill.
ac55tractor
Posted: 24 Dec 2021 at 6:15pm |
I had to make a choice. I really didn't want to pull the bearing and try again. So I drilled it.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8737 |
Posted: 24 Dec 2021 at 6:56pm |
What you did will be just fine. This isn't a Nascar engine.
ac55tractor
Posted: 26 Dec 2021 at 7:40pm |
Thank you
