AC 6080 oil leak
ecarmich25 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080 oil leak
    Posted: 23 Oct 2021 at 5:01am
anybody have any ideas on how to fix this oil leak on inside of tractor near fuel pump. also is the dipstick suppose to pull all the way out of engine tube and all ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 6:32am
Take the dipstick tube and in the area where it should fit tight in the block, use a center punch and go all around it making dimples like a golf ball. How deep and how many depends on how loose it is.  Clean the block hole with brake kleen on a rag and clean the dimpled area with brake kleen and let dry. Coat the dimples 100% with Loctite of some kind, red or green preferred and drive it back into the block using a punch on top of the hex area where it is solid. Let sit overnite or longer to cure.  I don't know what your other oil leak is....cannot see a pic.
Edited by DrAllis - 23 Oct 2021 at 6:33am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 6:32am
Not much info, but my guess is front plate is loose.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2021 at 7:57am
Sorry Mack couldn’t get pics to post
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 2:37pm
Anybody tell me if they able to see pics? Having trouble uploading don’t know if it’s my phone or need to use laptop
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 3:15pm
Can see pics but not really the oil leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 8:30pm
I agree, I don't see the leak either? Is it below the pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2021 at 11:03pm
Yes I believe it’s above the pump in the crack and goes down on the wall inside pump And then on the floor. saw the bolts up front and they were loose so I tighten up up but still leaks
Think seal is broken and was wondering if anyone had ideas to try bc I think only way to do it right is to take whole
Engine out and remove radiator and hood? Just looking for advice before I do a whole bunch of work that I don’t have to
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 6:12am
The black paint always makes it harder to see the source, clean it up and look for the highest point where the leak starts. Another thing that sometimes gets overlooked is to be sure the blow-by tube is not restricted with a bug nest, mud or kinked.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 6:51am
If the bolts was loose on front plate, that is the leak. Gasket gets worked out, and later will crack oil pan.
Replace dowel pin and rebuild dowel pin holes in front plate or replace.                           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 8:38am
Easiest is too remove grille, radiator then crank pulley to get to that seal - check bolt holes and use lock tite on the bolts
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 10:02am
F Y I; Red loctite was used at the engine plant on the dipstick adaptor to the block.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 8:59pm
If the dowel pins and holes are worn, nothing but new parts will hold it. Then if it has a loader or is used on rough terrain where axel bottoms out on stops, it will happen again.                         MACK
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 9:13pm
Your intolerance to and resentment of this oil leak is a little disturbing. For me it would be more worrisome to have no leaks as I would then be concerned I would be out of oil.
Just messing with ya. Hopefully it won't be too involved to get it stopped. My experience is 50/50 as in half the time it leaks worse after I try to stop it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
