An XT ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: An XT ??
    Posted: 21 Sep 2021 at 5:51pm
I drove past a farmstead that I knew had a series 1 XT on the property (with  a cab) as I've driven past the place for several years. I recently saw the RH side of the tractor parked close to the road and saw a circular "cover" on the side of the lower/front sheet metal Confused ?? I've seen pics on Tractor House listings but never gave it much thought, what is the purpose of the round hole ?? Thanks
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 5:59pm
Air filter access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 6:00pm
Air Filter- some had hinges - was a crude way to do it but it worked
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 6:15pm
Thanks guys, I never dreamed of the A/F  access. Did the "grill" not remove as easily as the series 2/3 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 7:03pm
grill is essentially the same, just difference in appearance, but the element was too long to get out of the air cleaner without the access hole. The hinged panel is on some 200's I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 7:41pm
Gotcha, makes sense now Wink . Thanks
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2021 at 8:35pm
Yes, the 200 has a hinged door.
Edited by allisbred - 21 Sep 2021 at 8:37pm
This page was generated in 0.301 seconds.
