HD3 Dozer
DoubleFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DoubleFarms Quote  Post ReplyReply Direct Link To This Post Topic: HD3 Dozer
    Posted: 23 May 2021 at 4:49pm
I have a HD3 diesel dozer, need to work on the ejection pump, is there timing marks to line up before I take the pump off.  Where can I send pump to get it worked on.  Thank You
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2021 at 5:40pm
Align the 2 marks inside before pulling it off. People send me pumps for rebuild from all over the country if you don't have anyone close you can trust. It should be a RoosaMaster DB, which there's been many write ups on this page about the removal and installation. Might need to search Allis 185 injection pump removal, seems there was a very well detailed writeup.
vernT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vernT Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 7:15pm
Hi, We are looking to pull the pump off our 180 to get rebuilt.  We took the plate off the pump window and turned engine over but do not see a mark on the disk that rotates.  The fixed disk on the left has a mark near the bottom of the window.  My thinking is that since the flat at the end of the pump drive shaft is supposed to be marked and the hub inside the pump that accepts the flat supposed to be marked so you can't get the pump off by 180 degrees, if you scribe the pump to the engine and you put the shaft into the pump correctly (not 180 deg off), the pump would have to be in time when reinstalled after rebuild.
What are you thoughts on this.  Is this correct or am I missing something here.  What do you charge and what is the turn around for a 180 pump rebuild? I would also need to buy or borrow a tool for the umbrella seal.  My emails is: vernon_tipp@yahoo.com.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2021 at 7:52am
Take the injection line bolt out of the pump for #1 cyl, (taking all out anyway to remove) look in the hole, you will see the port line up about the time the mark will be close. #1 cylinder is 3 o'clock position as viewed from the seat. I loan the tools out when I rebuild pumps, maybe your shop will too.
Bodnarboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bodnarboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 7:20am
Kinda jumping in on here. Awaiting my arrival of a 1970 180 w/500 loader. Seller contacted me yesterday advising all the diesel he found in crankcase. (His brother recently rebuilt pump). My assumption is he rolled one of the seal on installation. Am I able to obtain them seals at Napa? Or somewhere particular?
Billy from MD
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 10:53am
don't think NAPA carries those, I buy mine from a local injection pump repair shop.
Or ED may sell them to you as well.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 4:56pm
best to get locally if possible, JD, IH or Agco dealers have them, as well as pump shops. I try not to get carried away selling small parts online lol!
This page was generated in 0.221 seconds.
