Ford question
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: Ford question
    Posted: 30 Jun 2021 at 7:07pm
Ok guys. I been working on trucks/cars since the 1960's. Son tried to help his neighbor out buy buying his 1994 F150. Short wheelbase, 5.0 motor 4 speed. You start it up. Not moving or moving. No dash lights/warning lights come on but there is a constant beeping sound comming from under the dash.   Any ideas? Never heard or seen it before.
Edited by HD6GTOM - 30 Jun 2021 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 7:19pm
there is a separate fuse for the dash lights/ warning lights... might check that..... if the fuse is OK, the dash lights come on with the head light switch / dimmer switch..
ding , ding, ding when the door is open... Is that the beep ?   Door switch might be  STUCK or broken.. spray with WD40.
Edited by steve(ill) - 30 Jun 2021 at 7:22pm
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 7:22pm
Likely an air bag sensor.  Check for computer codes.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 7:27pm
do you have an  Air Bag Light on the dash ( over by radio) ?  If the BULB burns out, you will get an alarm that tells you to replace the BULB.
Edited by steve(ill) - 30 Jun 2021 at 7:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 8:38pm
1987's did not have air bags. The only thing stock that should beep is the headlights left on when the key is removed and the door opened or the key left in the ignition when the engine is off and the door opened. I would suspect the headlight switch but that should not affect the warning lights. That 5.0 and the 4spd (3spd w/overdrive) is a great combination.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 8:55pm
Guys my apologies. Its a 1994 5.0, 4speed with overdrive. The hydraulic clutch is low on fluid and I can't find my brake fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2021 at 6:03am
my vote's for the driver's door switch.
my '97 did that  ding-ding-thing, blew compressed air ,then some wd40, been fine ever since...til tomorrow, right ?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2021 at 8:10pm
I had a problem with one of my trucks with the door switch. My dome light stayed on all the time, which was pretty annoying at night.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2021 at 10:21pm
'94, code might be a little sparse
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 2:28am
Air Bag warning light is burned out. Pull the cluster and replace the bulb.
This page was generated in 0.555 seconds.
