190XT tilt hood?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT tilt hood?
    Posted: 26 Jun 2021 at 7:33pm
After my recent purchase of a 160. I cant help but think of a tilt hood on my 190XT. The tilt hood on the 160 is so handy and gives easy access to the engine. Removing the straight pipe to tilt the hood is no big issue, and adapting the air cleaner really doesn’t seam like a big obstacle. I haven’t looked into the mounting of the hood pivot points yet. Just something I’m gonna investigate some time. Anyone else thought of doing this? I have already modified my grill, got rid of the terrible design latches and bolted the grill to the hood so I wouldn’t have it come unlatched and run over it like so many have done. Grills are about non existent.
What’s your thoughts?
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 7:57pm
I have though about this at length. Grill would have to stay removable. Hood would have to pivot up slightly before it tilted forward, (to clear radiator neck) which means can't do a single hinge point. Hinge linkage would have to be between hood and front radiator side supports, which would remain stationary to hold the radiator. I would use door shock type absorbers to keep hood in tilt position and a quick release system on rear of hood to hold it back down. Of course the voltage regulator would have to be relocated and the dash cover could hinge rearward like on the 170/175. But the muffler/pipe would have to be removed to make the tilt hood possible.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 8:07pm
Alex, forgot about the radiator neck, so good point there. Wonder how much that opening would have too be enlarged to prevent a double hinge? Wish I had a junk 190 to play with, really don't want to do trial and error on my painted XT lol! Removing 4 bolts to remove the grill is no big deal. I don’t have the front weight on it and without looking at mine at the moment I’m thinking my grill is beyond the front end. Like I saiid, I will look at it at the farm. It hit me while I’m at home in my recliner haha.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 9:00pm
On my 190 pulling tractor, I just made hinges at very front.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 9:04pm
Mack, did you have to do much modification to get it to work?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2021 at 9:39pm
No, but nothing through hood. Ex out the side, no radiator.
You could always extend regulator wires to pivot and back. Attach cowling  at front with two small hinges. Use latches like grill at back of hood. Put cross braces in front of radiator to support front (like 170).               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2021 at 7:45am
Always thought it'd be easy enough to do, need a front square frame hinge it at the front, and mig the side panels on- Mack how do not run a radiator? Is the tractor block/ head full of hard blok? Curious cause I'm playing with this idea
Edited by DougG - 27 Jun 2021 at 7:51am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2021 at 8:47am
Been contemplating this for several years now for my 210 puller. The pipe on a puller is easy enough, just make the pipe a stub off the turbo, then bolt a larger one to the hood that tilts with it, then sits down over it, and a metal plate seals it up some. Not sure it would be good on a stock farm tractor though lol! Been trying to figure a simple way to make a hinge at front hidden behind grill. Love to see some pics.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2021 at 8:53pm
Aluminum head and burns enough alcohol to cool it.              MACK
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 1:28am
Have to confess I do have a red tractor in my farm fleet, CIH 7110 to be exact, the hood on them does tip forward on a compound hinge, that may provide some assistance with the fabrication. Good luck and post pictures along the way
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 8:23am
Yup, more complicated but will balance better. Plus you wont rip the radiator neck off.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2021 at 10:47am
Also consider the links on front of hood on a B1 Allis lawn tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 7:25am
Why not consider the hinge point at the rear of the hood ??
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 8:00am
why even bother I've had the hood off once in 10 years.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2021 at 12:17pm
Looking forward to the pics for this modification... tilting hood.
 Like to do it to a 170, specially for changing the battery out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 9:40pm
Will try to get a better picture but this is the hinge assembly for the tilt hood on my 160. Very simple design. This design would require the grill, front hood side shields, and hood be wielded together. Sure makes maintenance easy and not difficult to remove the hood. 4 bolts and it can be removed.
On a 190, make a new bracket to mount the electrical components on so they can be removed from the hood. If I had my 160 before I painted my 19XT, I would have been willing to try this. The grill extends beyond the front bolster so that would not be an issue. There is a frame wielded to the the 160 hood to support the weight.
Edited by AC720Man - 28 Sep 2021 at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 9:54pm
This is a picture I took when I first bought this 160 as I was in the process of removing the engine to do a full rebuild.
Edited by AC720Man - 27 Sep 2021 at 10:05pm
This page was generated in 0.199 seconds.
