D17 governor broke |
chainweaver
Joined: 09 Feb 2014 Location: west central m Points: 62 |
Topic: D17 governor brokePosted: 25 Jun 2021 at 9:55pm |
Friend's d17 governor gear broke in half & both weights are in the oil pan no doubt. Can he replace the assembly without dropping oil pan & fishing out the parts? Also the gear that runs it broke 1 tooth, does he have to replace it or can he get by? I'm sure it's been covered many times, I just can't find it. Thanks in advance.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Posted: 25 Jun 2021 at 10:04pm |
Have heard tell of gov weight going through drive gears and creating a burr on a tooth which led to bad harmonics causing more governor failures down the road. As Dirty Harry asks,"Do you feel lucky"?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 25 Jun 2021 at 10:15pm |
You can either fix it right or fix it again. Your choice. Drop the pan and make sure you get every piece of metal out of there. Also replace the gear and everything else that got damaged. Cutting corners in engines typically do not help long term reliability.
Posted: 26 Jun 2021 at 5:52am |
Radiator and front support must be rolled away. Front pulley and timing cover and starter and oil pan must be removed. Now fix it. All THREE gears with new weights and pins. Be sure to check the governor assembly for gear backlash as the dowel pin may be missing. If people would replace governor weights every 1,000 hrs as a maintenance item, this would never happen.
MACK
Posted: 26 Jun 2021 at 7:17am |
Rough teeth on gears will destroy weights. If gears are rough, replace them. MACK
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 26 Jun 2021 at 3:13pm |
This one area of the 226 engine where a little preventative maintenance can prevent very costly repairs. It is not that difficult to pull the governor and check the condition of the pins every now and then.
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1731 |
Posted: 27 Jun 2021 at 7:16pm |
I have a govenor and cam if needed
phil
