Torque
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: Torque
    Posted: 10 Apr 2021 at 7:17pm
Hello Gentlemen, I'm putting the head back on the 170 gas, and was wondering what everyone uses to get the proper torque values on the nuts that hold the water outlet to the block.  Was thinking of using a crow foot adapter, but wasn't sure if that would effect anything or not.  Any advice is appreciated, thank you!
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 7:22pm
Should have said water outlet to the head
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:12pm
There was a special tool for that. Easy to make.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:18pm
I had no luck using a crow foot. Ended up getting a 2" long box wrench with ⅜ square drive on the end then calculated the new torque wrench setting.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:24pm
Mack, do you have pics or any info on this tool ?
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:27pm
plummerscarin, how did you the recalculations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:45pm
https://belknaptools.com/extensions-calculator/
Edited by steve(ill) - 10 Apr 2021 at 9:47pm
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 9:18am
Thanks everyone, I'll see what i can come up with.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 11:36am
if the adapter is at a right angle  no other calculation is needed  , only 90*
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 12:10pm
Are you referrig to something like a distributor wrench?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 12:36pm
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 8:01pm
Many thanks, gentlemen!  Going to order an adapter tomorrow.  Thanks again!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 8:38pm
Yes, like a distributor wrench with square drive in top.          MACK
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:44am
Thank you Mack!
