Torque |
DCAC ![]() Orange Level ![]() Joined: 20 Oct 2018 Location: east central SD Points: 511 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2021 at 7:17pm |
Hello Gentlemen, I'm putting the head back on the 170 gas, and was wondering what everyone uses to get the proper torque values on the nuts that hold the water outlet to the block. Was thinking of using a crow foot adapter, but wasn't sure if that would effect anything or not. Any advice is appreciated, thank you!
Should have said water outlet to the head
There was a special tool for that. Easy to make.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3870 |
I had no luck using a crow foot. Ended up getting a 2" long box wrench with ⅜ square drive on the end then calculated the new torque wrench setting.
Mack, do you have pics or any info on this tool ?
plummerscarin, how did you the recalculations?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87090 |
https://belknaptools.com/extensions-calculator/ Edited by steve(ill) - 10 Apr 2021 at 9:47pm |
Thanks everyone, I'll see what i can come up with.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3864 |
if the adapter is at a right angle no other calculation is needed , only 90*
Are you referrig to something like a distributor wrench?
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 962 |
Here is a link to some at McMaster Carr.
Many thanks, gentlemen! Going to order an adapter tomorrow. Thanks again!
Yes, like a distributor wrench with square drive in top. MACK
Thank you Mack!
