Ac rake/tedder
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: Ac rake/tedder
    Posted: 02 Apr 2021 at 8:52am
are these a rake and tedder? They work good? Worth 200.00 works just has bent caster wheel in back thanks
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 9:30am
they tend to rope the hay. I use one and 200 is a good deal but if you are planning on doing more than a couple of acres, the new holland rakes are a good investment
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 10:38am
I had one for many years and it was all I ever had. If you're twisting a rope, it's not adjusted properly. The manual explains how to properly set the pitch of the teeth. They will do a nice job of raking or tedding on well prepared ground that is smooth, without ridges or ditches. The main problem is they will break the gearbox easily if the slip clutch is adjusted too tight or the drive chain is too loose. Gearbox & driveshaft parts are slim to none, as well as are many other parts. Newer rakes would have better parts availability.
 On the plus side, if you're raking 2 windrows together for a Roto-Baler they will be straighter and more consistent, because of the length and the fixed wheel at the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 12:50pm
Ok thanks I have a new Holland 258 that we actually use this would b more of a toy
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 2:20pm
I raked hundreds of acres of hay with one in the 60, 70. And 80's. They are a good rake as long as you have level ground. Most still use the ball and socket hitch.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 7:29pm
Used one for years---NEVER had any trouble making nice rows wit it.
