D-15II
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: D-15II
    Posted: 31 Mar 2021 at 11:44am
I recently acquired a D-15 series 2 and it's missing a carburetor, what carb does it usually have on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 11:51am
I would look for a Marvel/Shebler. Just like those better than Zenith. But that is just me. My guess is it could have either?
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 11:58am
My D15 has a Marvel Schebler carburetor on the tractor.  I am sure this was from the factory because the tractor only has 1800 hours and the meter does work.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:12pm
Marvel Schebler carb# is TSX869 For S2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:13pm
No Zenith ever on a D-15 S-2
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:14pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:15pm
ours has the TSX-869 on it
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:17pm
https://www.carburetion.com/Products/SearchAll.aspx?Search=tsx844
https://www.carburetion.com/CarbNumber.asp?Number=TSX-844%20(235537)
Edited by steve(ill) - 31 Mar 2021 at 12:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:37pm
G-149 in early D-15's have a much smaller carb than the G-160 in the series 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 4:11pm
The service manual I have says they started with MS   TSX 815.  After serial #3359 they went with a MS  TSX844.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 4:43pm
My Series II has a TSX-844
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 10:02pm
Both of mine have 869's on them. Tracy
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 7:59am
Carb as found on D15 II I'm currently stewarding......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 8:11am
A Marvel carb from a series 4 D-17 can be made work by changing the throttle shaft or welding a new lever to the D-17 shaft.
