Ac 5040 toplink pin
Smithmatthew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithmatthew Quote  Post ReplyReply Direct Link To This Post Topic: Ac 5040 toplink pin
    Posted: 14 Mar 2021 at 8:50am
Putting the top link pin in a 76 ac 5040... the thing looks like it opens up some where the pin can be installed but I cannot figure out how to work it I go to install my pin and it hits on either side and I cannot put my lynchpin in
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 9:57am
Is the label on the pin preventing it from going in?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 3:45pm
In the picture the two sides look like they may be bent out.  If that is the case your pin won't go thru because the holes are not aligned.  If that is the case you may have to go with a smaller pin.
johmor15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johmor15 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2021 at 4:04pm
on my 5040 the pin is ground to a slant on one side at the end you would hold to push it thru the holes on the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithmatthew Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 6:39am
No the lip on the end of the pin hit and catches and wont let it slide in I was thinking the way it looks is like the whole thing is a spring
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithmatthew Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 6:41am
I can get a shorter pin to go through it but it don't quite go through far enough for me to put a linchpin in to lock it into place
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 9:00am
Grind a flat spot on the head end to create clearance. Make it parallel to your lynch pin hole.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 11:56am
Looks like the top link is dead heading against the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 4:25pm
I didn't mean shorter, I meant smaller diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 5:17pm
Try a well worn TL pin.  Either the bracket is sprung, the eye on the TL is too fat, or the new pin is too thick.  Or some combination of the 3...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithmatthew Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 5:33pm
The way it looked I thought the assembly moved in and out and that was my problem but I guess not... thank you all
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 7:07pm
Thinking about it the Fiats come with a special top link pin,might be a metric size.
This page was generated in 0.146 seconds.
