Allis B clutch pedal pivot pin
Jcone1025 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B clutch pedal pivot pin
    Posted: 01 Mar 2021 at 12:07pm
     Does anyone know how to remove the clutch pedal pivot pin on a 1940 B? Thanks
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 1:18pm
It's typically held in by cotter pins on each side of the torque tube.
The pedal tends to fuse to the pivot shaft, but it really doesn't need to come off.  As long as you can get the far pin out and slide the shaft, with pedal, out of the torque tube.
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 1:33pm
Wow thanks Ben. Is that image from a specific parts manual that I should own? Clutch pedal and pin are worn so bad that the pedal skips past the stop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 1:53pm
Image is from Agco's Parts Book website:  Welcome to AGCO Parts Books (agcocorp.com)
Click on the "View Books" button under Guest User and you're in.  Incredibly useful for these old machines!
