8550 ELECTRIC FUEL PUMP?
Gavin3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavin3 Quote  Post ReplyReply Direct Link To This Post Topic: 8550 ELECTRIC FUEL PUMP?
    Posted: 01 Feb 2021 at 10:13pm
Was just wondering if the electric fuel pump on a 8550 or 4w-305 was an factory option or if that was something people added onto the machine. I am wanting to installed one onto my 8550 and I was wanting to install it were it would be if it was installed at the factory. But I have no idea where it would be mounted. if they were not a factory option I will probably installed an after market one onto the machine. Just wanted to pick your guys brains on this one for a bit. Thanks
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 6:46pm
Agco parts books don't show an electric lift pump for it.  Our 8010 has one, but the 8050 does not.  I had to replace the one on the 8010, but didn't want to spend as much as Agco wanted so I just bought an aftermarket one like Carter makes.  Doesn't need to be very much pressure.  So far it's been working fine.  It's mounted inside the frame rail so it doesn't get bumped by anything.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:13pm
ive used 2 different transfer pumps both work well on my 7080  one was a holley pump  we bought from a race car supply store and the other is a eldrabrock i bought from oreliys auto parts store they make them for gas and diesel  they mount inside the right frame well  it was around 85.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavin3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 11:06pm
Ya thats what I was thinking I was gunna do. Thanks for the info fellas.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 4:25pm
I believe the factory "kit" was a Holley Red. Primarily for 7000 series with the 426 engine with the Roosa pump. Not sure they offered it for the big girls.
The cheapies at the auto parts store cant even keep up with demand on a lowly old 6.5L GM diesel pickup, so i'd avoid them,
If you can swing it, I'd consider a Fass or airdog system. A little more budget friendly but good flow is a Raptor pump.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 6:45am
I bought a good quality electric pump from inj pump Ed (on the forum here) for my 8550. Mounted it down by the base of the fuel tank, so it is gravity fed an ample supply of fuel, then ran a line up to the filter housing. It is adjustable pressure, and I have a fuel pressure gauge on it. Turn it on and off with a toggle switch. I really should wire it onto a relay and run it off the key switch. Works good. Darrel
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 7:44am
we have a holly red pump on our 7580
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 9:01am
You can use Carter # P4594 or NAPA FE0539 6 to 8 lbs PSI
Dave974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave974 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 9:35am
This is the pump I've been using on my 7080 and seems to work well.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 6:56pm
My late 7020 has the factory electric pump and it had a "red Holley pump" I got a new one identical to it from Summit Racing for about a $100 bucks.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
