190xt hydraulic pump rebuild
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Topic: 190xt hydraulic pump rebuild
    Posted: 18 Jan 2021 at 6:40pm
I am in the process of rebuilding my 3 section hydraulic pump on my 190xt III. I was able to get all the gears and plates and everything i needed from AGCO, however I will have nearly as much into this pump as i will into my engine overhaul. Anyway my A-C service manual states that a Loctite sealer should be used in between each section when assembling. So I'm just wondering exactly what i should use? It states to put it just inside the bolt holes of each gear plate.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 9:15pm
Use a very small amount of red Loctite.          MACK
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 8:31am
I used loctite 515 on the last one I did.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 1:57pm
We have rebuilt dozens, never used anything with the new type seals.  IF a  pump has blown out we check them on a flat glass and fine wet sand paper to make sure they are flat.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 9:36pm
I'm with you thran, I never use any sealer . It's  good insurance for a first timer.            MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 1:20pm
Would it have been cheaper to buy a new pump? I have no idea on the cost of rebuilding that pump but my 200 was kinda rebuilt by a AGCO dealership. They resealed it, but no other parts, and they flushed the system supposedly and new oil and filter and replaced a hose that goes to the oil cooler and my bill was $2000. A new pump is $2000 from AGCO. I didn't expect that cost and I wish I would have just bought the new pump and did all the rest myself.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 7:08am
Only replacement pumps available are from A&I i believe and they're $2300. They also do not have bearings in them.   Just bushings and they don't last is what i was told.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2021 at 7:27am
It would be interesting to follow up on that claim of "don't last as long".  I know of quite a few older 190/190 XT's (this is the pump we are talking about) that may have went 5,000 hrs without any failures and when they did it was probably just a reseal job or a blown section plate, not a bearing rebuild. A tractor that had a loader on it and was used everyday would be a real test unit. None of these 50 yr old tractors get the usage they did 50 yrs ago, so if that new pump only lasted 3,000 hrs, that would be a LONG time in my books. The hydraulic pumps on many of the Gleaner combines (K-F-G) had bushings in them and a belt yanking the shaft/pulley sideways all day long and they seemed to hold up pretty well.
Edited by DrAllis - 23 Jan 2021 at 7:30am
