Wheel Painting
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Painting
    Posted: 01 Jan 2021 at 3:39pm
When repainting the front wheels, what is the preferred/easier order?  Paint the cream, then mask off and paint the silver? Or paint the silver, then mask off and paint the cream?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 9:53pm
I don't think there is an easy or preferred way.  I told my painter how they should look and let him do it.  He did say it took a lot of time.  The question is:  Do you want it done fast or do you want it done good?
I had these done last winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 10:12pm
What series and years were they painted that way?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:23pm
Paint them all cream or all orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:25pm
Not familiar with that scheme myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 5:35am
gee, I'd love to know HOW the factory did it ! All I see is a LOT of tape and time needed to properly mask them and I can't see any mfr doing that unless they had  some 'tricks' up their sleeves.I'm thinking shoot the centers,wait a day,mask the centers, shoot the rest, wait, then remove tape.... still seems like a LOT of $$$ work for rims though....
be interesting to know how DS4's were done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 7:10am
Mine is a Series 3 D17.  Here's what my Grandpa's D15 looked like when new.  I'm going with this style.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 7:27am
I found painting the outside(silver) first and then the cream on the center second.
I used a lot of newspaper and some tape to wrap everything up that I didn't want painted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 9:29am
I guess I have done it both ways. But the last ones I did I used some different aluminum and sprayed it first. I had over spray on the centers. Well the cream did not like the silver. Took a month to dry. So try to get paint that is compatable is my point. Same brand primer and top coats. I have used rustoleum spray cans for most of mine.
I Think your tractor is going to look awesome with those! I tend to go with more of a cream than a stark white. Just happens to be what I like.
some pics:
These are from my rear of the WZ pulling tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 3:26pm
Has anybody tried to do the centers first and then put a piece of cardboard over the center and spray the silver?  Or do you think too much over spray will get on the cream centers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 8:12pm
I am sure a well designed mask would work pretty well. I am always to lazy to build the mask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 10:23pm
You would still get overspray, and you would not get silver in the slots between the rim and center.  If I recall, my painter did cream first, then taped and covered mysteriously - said he ended up using a deck of cards somehow.  I didn't see how he did it, but I am happy with the end result.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 1:32pm
Well, I painted the silver first, then the cream.  I used rattle can Rustoleum - Aluminum for silver and Almond for cream.  Came out pretty good.  Good masking is crucial.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 2:04pm
DSeries4 I would guess he slid the cards under centers where they attach to the rim. Maskings not that hard just time consuming. I always hated when someone paints the rims and gets over spray on the tires!
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 3:46pm
MDM 1. Someone posted on here a while ago that a solution to keeping overspray off the tires is this. Cut a circle, just smaller than the outside diameter of a rim bead, in a piece of cardboard. Then deflate the mounted tire and cut the cardboard from the outside to a point on the circle. Slide the cardboard between the tire and rim all the way around. Then paint. It keeps the paint off the tire and eliminates the damage to the paint if you mount the tire after the rim is painted. I used this on the D-14 I am restoring and it worked great. Bob@allisdowneast
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 5:00pm
Sounds like a great idea!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 5:34pm
GSTROM99,
The front rims look awesome! You did a good job! Were they sandblasted? I like that paint scheme. But that's just me!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 6:38pm
Dismount tire and blasted.
POR15 inside rim then mount tire when dried. Do not inflate tire yet. 4 mil plastic cut smaller than rim diameter for a snug fit.
I would think painting center first then masking for rim would be easier. I'll let you know when I get that far.
Edited by plummerscarin - 03 Jan 2021 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 8:37pm
Thanks!  The front tires were bad, that's why I pulled 'em all apart.  New Carlisles are 'en route.  They were not sandblasted.  I just ground the rust off the inside, sanded smooth with 120 grit, masked, primed and painted.  If the tires weren't so bad, I wouldn't have done this, but I'm glad I did.  I'm not doing a restoration, since it runs good and I think this was a good "barn find".  I had to weld up a rusted hole, which I found when I got them cleaned up...
I'm going to have to be careful, when I mount the new tires.
Edited by GSTROM99 - 04 Jan 2021 at 8:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 8:48pm
I had painted some Cub wheels and mounted tires afterward. Even with plastic guards on the irons the paint got chipped. That is why I mounted the tires first before final paint on those 7060 wheels. Inflate the tires after the paint dries. No chips, no overspray
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 8:11am
Plummerscarin, I like your idea too. Bob@allisdowneast
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 11:25am
I sprayed the cream centers first and then hand painted the Kentucky chrome next.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 7:21pm
Originally, would the rims have been galvanized and the the painted center riveted in?
AGCO My Allis Gleaner Company
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 7:29pm
Careful masking helps...I have painted lots of wheels by mounting them on a spindle or axle and turning them as I paint...a steady hand stops overspray....done it on spin outs...spin all the way out , paint, spin all the way in..paint.....Mark
This page was generated in 0.209 seconds.
