G grader blade
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: G grader blade
    Posted: 01 Jan 2021 at 7:21am
 Have any you guys have or seen a grader/belly blade for a G ? I would kind of like to have one .
Dusty
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 2:56pm
We had one fabricated to use as a snow plow blade for the G.  Worked fine for us on the light snows we usually get in Maryland.  It was a simple blade mounted with two arms that hooked to the tool carrier arrangement.
Meyer made a snow plow with I beams that hooked to the drawbar and reached to the front of the tractor.  Remember, the G is not a powerful tractor so you cannot do the tough pushing.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 6:10pm
internet picture.... home made..
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 4:57am
check Craig’s list in the Sacramento Yuma city area there is on listed there
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 8:23am
Check this 'G'. Hard to steer without front weights. Hard to steer with front weights. LOL    Ross D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 8:52am
now thats just crazy !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 8:50am
   Hi.    In response to the original question, I understand that this 'G' owner has a cottage gravel roadway that requires a lot of maintenance in order to access his cottage. It is located on the Cambrian Shield in Ontario. I suppose a lot of washouts and normal gravel maintenance is required.
   This man commissioned a local fab shop to do the design/build. Money was not a problem. In cottage country, I know of several 'D' graders that you can contract to do the same job.
    Fun in the Sun.
   Ross D.
