Tire options?
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Topic: Tire options?
    Posted: 17 Dec 2020 at 12:46pm
We have a series 1 D17  with 18-4-26 tires and spin out rims. Was this an option or did someone take D14-15 spin out center and put a18x26 rim on it? This is the only one i have seen.It makes a real nice tire for the tractor.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 6:20pm
  The early D17's had 14.9x28 tires standard.  Later ones 16.9x28 was a option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:03pm
I'm surprised they clear the finals...
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 8:56pm
What size are the front tires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 9:08pm
D17s were never offered with 18.4 x 26 tires, although later models could be had with 18.4 x 28 tires.  I have never seen a 26" power adjust rim wide enough to accept an 18.4 tire either.  18.4 x 26 is a popular size of combine tires on fixed width rims though.
I would like to see a picture.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 9:46pm
I have a D 15 that has rice features and has the same wheel on the rear as you describe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 8:33am
The D17 parts book lists a 14-26 (new size 16.9X26) tire for Grove tractors. Nothing is said about rim with , but a 18.4X26 tire would go where a 16.9X26 tire was
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 9:09am
But, unless there is something really special about a 26 inch power shift wheel, it will not clear the final drive on a D-17 when spun clear in.  A 26 inch fixed wheel works, but spin out doesn't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 1:11pm
After getting the tire off the tractor the rim has been split and 7 inches have been added to the inside making   a total 18 inches  outside to outside. With no rails on the inside the tire can be moved in till it almost hits the finder. The tractor has a 170 picker on it and the wheels shifted all the way clear it by an inch. The rims look to  have been modified by a shop or skilled welder. This size tire is great for traction and flotation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 1:23pm
YEP......... a couple pictures of that would be nice.. Rim work, and one mounted on the tractor !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 1:58pm
If we can figure it out i will post pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 8:05pm
Text me the pictures I can post them if you want.
314 954 2599
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2020 at 6:50pm
Here are some pictures of the wheels that was sent to me.
