allis b |
john2189
Silver Level Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 297 |
Posted: 30 Oct 2010 at 12:01am |
hi
where is the proper locations for the choke and starter rods for my 42 and 5 B ?
one is missing both and the other is cut,bent and welded on. it is mounted on the battery box with an angle iron drilled.
Does anyone have pics of the way they should be ?
John
'41 Allis B
'45 Allis B '49 Farmall Cub '72 IH Cub |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6353 |
which way is your starter turned? Wire connection on top or bottom?
Charlie
Dick L
(Proper) Location or the Location from the factory.
The starter pigtail rod is is mounted under the battery box thru an angle bracket mounted under one of the battery box bolts. The choke rod was mounted thru a hole in the pin that goes go thru the top of the post and brackets that hold the steering tube to the post. There should be pictures in my fotki site somewhere. Edited by Dick L - 30 Oct 2010 at 8:44am |
Dick L
Here be a couple pix of the starter rod.
Dick L
Here is the choke rod upper location.
john2189
OK I have the rod for the starter but my throttle shaft isnt as long as Dickl's and there is no hole there for the choke rod
'41 Allis B
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22816 |
Dick's picture appears to show the choke through a clevis pin that holds the steering tube to the support post. If yours isn't long enough, take it out and replace it with a longer one. I wonder if your tractors came with a starter delete plate originally. Lots of War tractors didn't have a starter but may have had the torque tube for one. If they didn't have a starter to begin with, they wouldn't need a choke control at the operators station, only at the carb.
Ken in Texas
Orange Level Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Above the toolbox door on my CA there is a additional flat metal clip under a upper tool box machine screw . The choke rod goes thru this clip. Not sure if the clip is used on Bs.
GlenninPA
Orange Level Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Yes Ken, I have that clip on my 1950 B, which is my only electric start B (that is in this state....)
Dick L
I think all had that clip or guide bracket that came from the factory with a choke rod.
Ken in Texas
Parts books show the Choke Rod Clip Part # 210919 with the #900561 Screw,# 904205 Lockwasher and #900366 Nut on B/IB and C after B-55300
There is also supposed to be a Choke rod return spring #211320 on the carb end of the rod. None of my rods have this spring. It hooks to the Carb Choke Lever. Can't see from the diagram where the stationary end of the spring hooks on past the carb.
Dick L
The spring makes sense since so many other makes of carburetors have the choke return spring. On most the spring is part of the carburetor and not an added spring. The spring works real well on my Farmall C but you still have to push the choke back in on my Olivers that have the return spring.
Charlie175
Some of you beat me to it, but here are some more pictures
Charlie
john2189
Thanks for the pics
My Bs do not have that straqp on the back of the gas tank either as shown in Charlies pics, they have two lugs that bolts to the toolbox
'41 Allis B
Charlie175
Interesting, I'd like to see a picture of the tank.
Charlie
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2203 |
In what year did the B change to the pull starter rod located up on the steering column? |
RichinWis
Orange Level Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
They changed it to the pull rod in 1951 when they started making the CA, the gas tank, hood, starter,and all that stuff back there was standardized then.
