Wheels for WD45
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Topic: Wheels for WD45
    Posted: 02 Dec 2020 at 7:44am
Is there 5 bolt wheels anyplace that fit a WD45 for 7.50 tires? If not is there a 6 bolt hub and bearings that will fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 9:08am
50 years ago, my Uncle had some Buick or Pontiac wheels with wide tires (9.5 L x 15?) that fit on a WD45 wide front. So, yes, there used to be a GM wheel that fit the 5 bolt pattern and was wider than an AC wheel.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 9:30am
x2 on the Buick....I have seen others with center hole rib trimmed out that fit also.  In fact I think I could get you a pic of that.....Dale
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 11:43am
5 x 5 bolt circle. Chevy pickups 71-90's had the pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 1:42pm
I measure the WD45 wheels. They have a 3 3/8 center hole. The Chevy pickup wheels have a 3 in center hole.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 2:23pm
Here's a couple shots of my 45, one with the Buick rims/9.5Lx15's and one with 7.50X15's on 6 bolt wheels. I did a project thread on here about converting to 6 bolt.
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2020 at 7:29pm
if you get the chevy 5x5 bolt pattern wheels, you can cut the centers out larger to fit. Did that a time or two and worked great!
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 7:31am
Where is the thread for the six bolt hubs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 8:58am
Note that this is just how I did this. There were WC's with six bolt hubs that may work, don't know. This was not a cheap endeavor! I do really like the results though.
