D15 front spindle
Pitbull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pitbull Quote  Post ReplyReply Direct Link To This Post Topic: D15 front spindle
    Posted: 07 Nov 2020 at 4:08pm
My D15 has the early one piece solid front axle (wide front end).
The newer design has a two piece adjustable axle.
The spindles are different - the obvious difference is the ID of inner wheel bearings.
Newer spindle may be slightly longer vertically - 12" as opposed to 11 3/4"
Can I use the newer spindles that are readily available and simply change the inner wheel bearing?
There was one washer at the bottom of vertical shaft.   My measurement of 11 3/4" was taken with washer removed.
The key way is very badly worn on my spindle.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 5:24pm
My advice would be to talk to Brenda @ Sandy Lake equipment, she'd know!Wink
