210 Clutch |
ACFarmer ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Ohio Points: 746 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Oct 2010 at 5:21pm |
How much horsepower will a stock 210 clutch hold? Reason is I just picked up a very cheap 210 with a blown engine and I have a good running 7080 engine sitting here. It wont be pulling plows and the like every day, be more like a planter type tractor but every now and then I'll probably use it for heavy work and want to make sure a stock clutch will hold or if I need to come up with something before I put this engine in. thanks!
Making a living farming with and working on Allis Equipment
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21853 |
A new stock clutch will hold 200 hp OK.......a worn stock clutch may not hold 100 hp depending on the condition.
i planned on putting a new clutch in while I had it apart, I just wanted to make sure I wasent wasting my money.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5095 |
If you plan to pull it with more than 200 hp, you may as well put in the heavy duty 30 spring pulling clutch, and 8 pad HD disc. I got mine from Allied Precision in Pocahontas IA. Not much more than a reman stock unit, but a fairly stiff pedal.
I might pull it sometime but it will still be used for field work and planting too. I'm not sure what I'm gonna do right now lol
