D15 ammeter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 ammeter
    Posted: 18 Oct 2020 at 8:35pm
Can a bad ammeter cause a tractor to not charge? Rebuilder says generator and regulator are good. Ammeter always shows discharge. Thanks Tracy
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 8:43pm
Tracy - Just had what you are going thru ! Took a week to find but , it was a poor ground on reg. Took me forever to find . Hope that fixes it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 10:51pm
yes, a bad ammeter can keep them from charging.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:02am
Absolutely. An Ammeter is a flow meter. It needs current running through it in order for it to tell you something. It also feeds current to the VR.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 8:45am
How can you test an ammeter? Thanks Tracy
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 10:34am
Hook up the ammeter in series with a battery (or charger) and a headlight.  Bulb should be bright and show a few amps of draw on the ammeter.  You can do this with either 6 or 12 volt.
Or if you have headlights on the tractor, just turn them on when the tractor is not running and look for the needle to bounce down to a small discharge.
Does your needle ever move at all?  And you're sure the meter isn't hooked up backwards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 10:40am
Meter is hooked up correctly. This just started a while back.  Thanks Tracy
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 10:40am
also you could put a jumper wire on the amp meter and a OHM Meter on your battery and see if its charging.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 4:22pm
I agree, trace where the ground is and clean it real good.  Then take the ends off the battery and clean them real good too.  I just had the same problem on a CA that was working well and then just one day...........It was the + side as that was my ground.  Quick fix.
