D17 expansion plug
Doobletango View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Topic: D17 expansion plug
    Posted: 18 Sep 2020 at 5:30pm
I’m trying to find a replacement plug that I removed from the back end of the camshaft. When I called Napa, I got a totally different freeze plug than I expected. From an initial search, I’m only finding plugs for 2.25” that I’m thinking won’t fit my 2.5” Bore.
Can anybody point me in the right direction?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 7:12pm
It has to be the "disc blade" shape design or it will block the oil drain hole. Where is the old one?? I always reuse them without issue. AGCO p/n is 70910011.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 1:12pm
I destroyed the old one removing it. I didn’t know it was reusable.
Thanks for the part number. When I install it, what should I use to seal it? I have black silicone and the 3M adhesive I used for the rear seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 1:55pm
How ever you use the sealer, you CANNOT plug that small drain hole at the bottom !!!  I always drive the plug into place and then take a punch and peen around the O.D. deforming the block just a bit in 3 places so it cannot ever fall back out. Clean the surface and brake kleen and smear some oil resist RTV all the way around with your finger to seal the gap and let it cure.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 2:21pm
I have the 910011 NOS plug in stock
920-598-1287
www.awtractor.com
A&W TRACTOR 920-598-1287
This page was generated in 0.813 seconds.
