7050 3 point ?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 7050 3 point ?
    Posted: 22 Oct 2010 at 6:12am
What should I expect to pay for a used extendable lower link? Just the part that slides out for easy hookup. Don't ask why mine is bent. Also, would it be advisable to heat it to straighten back out. It's not bent bad. Just enough so you can't quite slide it back into the socket. My gut says get a different one. Thanks.
Wink
I am a Russian Bot
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 7:26am
Take it to a good machine shop and let them press the bend out.  If you use heat that will temper the metal and potentially make it break under a hard pull.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:08pm
Local salvage yard wanted $50 apiece for them when I asked last spring.  Was going to switch my 8010 from Cat II to Cat III.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:17pm
The only way you can harden steel with heat is to get it to a "critical temperature" usually somewhere above 1600 deg F and quench it. Quenching can take place in air, oil, or water. Tempering is usually referring to the "draw" process that relieves stress and slightly decreases hardness. If you heat it up to straighten it and don't let it cool too fast you probably can't hurt it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 1:20pm
If it is only slightly bent, try grinding off the high spots and hand fitting it. That might be an easy substitute for heating or replacing.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 2:58pm
Heat it,straighten it,pack it in sand to let it cool very slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 3:22pm
Wrapping in fiberglass insulation works too.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2010 at 7:45pm
Thanks guys.
Wink
I am a Russian Bot
This page was generated in 0.211 seconds.
