Field Cultivator
CAPTMARCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Topic: Field Cultivator
    Posted: 12 Aug 2020 at 3:45pm
Ok don't shoot, this is about a Deere field cultivator that I stumbled upon and had questions.  I know its sacrilege but this forum has been so damn helpful I can't help but to ask:
Anyone able to identify this unit or know where I can find out how to utilize it on a 3 point?  I know I have to convert my CA over which is fine but I can't find a manual, pictures, etc anything on this hog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 3:46pm
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 3:51pm
Your member termination notice is being prepared.
LOLLOLLOL
Edited by TimCNY - 12 Aug 2020 at 3:51pm
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 5:33pm
The picture of the is for row crops.It will do two rows at a time.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 8:06pm
Back in the day, they were pretty good cultivators. Spent many hours on a four row.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 8:50pm
It is a row crop cultivator not a field cultivator.             MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 9:08pm
John Deere RG row cultivator. Spent many a day operating my Dad’s RG 830(8 row 30” behind his JD 4020 diesel. Usually they had two pipe gangs between rows. One longer pipe gang had a front & rear shovel(s). Another shorter pipe gang had a front & mid shovel(s). Both pipe gangs had front depth gauge wheels.
But like yours, a few models either had short gang removed by farmer or may have been ordered to only be one gang?
What crop are you going to be cultivating?
Edited by AC7060IL - 12 Aug 2020 at 9:20pm
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 7:34am
You asked: "How to utilize on a 3 point". I guess I don't really know what you're asking? The lower 2 pins are there, and a top link will go from the hole between the 2 straps up high in the front/center to your tractor. The gauge wheels will drop to the ground when you lower the 3 point, and away you go.
If that's not what you're after.....sorry and please clarify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 7:50am
Thanks for the replies!  I intend to use it mainly for food plots at our hunting land as we have a large (13 acre) farm field to monkey with.  I guess my main questions would be how to set this thing up and if anyone knew where to find a manual for it, stuff like that.  Ive been searching Google and coming up blank based on the model number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 9:31am
Not much to set up by the looks of it.  Hook it up and go to the field.  Adjust the length of your top link to get the depth of the coulters and cultivator shovels the same.
Hope you have some weight on the front of your CA.  That toolbar looks pretty beefy.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 10:53am
We have the folding 8 row big brother still use it set the depth gauge wheels and adjust the top link so it runs level when in the ground. They do a good job in the pinto beans that's the only crop we use it for. It's probably a lot to heavy for a CA and will leave strips since it's a row crop cultivator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 12:18pm
D Dave, I think he called it a field cultivator because he's going to cultivate a field...maybe not knowing there are "field cultivators" and row crop cultivators
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 12:42pm
Should be able to move everything in, cut some weight off and give it a try. Most that will happen is break the shoes off if ground is tight or stand up the CA.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 6:48pm
Sadly I will admit that when I was 10 years old, I hooked up our Burch 4x38" row crop cultivator onto the D-17 and "tilled" an end row (it wasn't planted yet) to see what could be achieved Embarrassed . Surprisingly in 6'th gear, 3/4 throttle and cross hatch pattern , it made an EXCELLENT seed bed Wink . Speed was the key !! Dad was at work and wondered how I did it when he got home, sadly I fibbed and said the disk Cry .
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 7:21pm
You will have to buy 3pt hitch adaptor for the CA to adapt your snap coupler hitch to 3pt hitch. It may be a bit heavy for your CA.
Edited by Ed (Ont) - 13 Aug 2020 at 7:24pm
